Author Topic: Window crank parts  (Read 5174 times)
Offline MY1978
  • Just a girl and her truck since 1978
Window crank parts
« on: May 23, 2021, 02:42:51 pm »
I am replacing my interior door panels.  When I removed one side, there was a large spring behind the door panel for the window crank.  Behind the other panel, there was a thick foam "spacer".  Which is the correct part so that I can order the correct replacement part.
Thanks.
Offline Rapid Roy
  • Euless, Texas
Re: Window crank parts
« Reply #1 on: May 23, 2021, 02:49:09 pm »
Both of mine has the foam. I believe it was factory. You can probably use any type of foam as long as you get near the correct length.
Mopar by Birth
Chevy by Choice
Offline MY1978
« Reply #2 on: May 23, 2021, 07:46:44 pm »
Thanks.
