Author Topic: 1990 Chevy C1500 TBI/305 stock  (Read 24133 times)
Re: 1990 Chevy C1500 TBI/305 stock
« Reply #15 on: June 17, 2021, 03:48:16 pm »
Quote
How are the plugs and wires? Check the exhaust back pressure.
Always start with the basics. Definitely get yourself and OBDI scan tool
Thanks again Vile.  I ordered a cable, hopefully my mid level scanner can work seeing run time data.
« Reply #16 on: June 18, 2021, 12:30:30 pm »
I use WINALDL on TBI trucks (as long as it is covered.  The 1991 with 4L80E wasnt at one time.
http://www.winaldl.joby.se/
I made my own cable with some electrical probes and a Ethernet jack.
You can see it here (you have to have a 9 pin output though.  http://forum.73-87chevytrucks.com/smforum/index.php?topic=7711.msg47384#msg47384
Used it to diagnose the Suburban I had.. http://forum.73-87chevytrucks.com/smforum/index.php?topic=3984.0
What about the IAC?
Pull the distributor and check the mag pickup the burb I worked on had them rusty and bad..
« Reply #17 on: June 18, 2021, 02:33:10 pm »
What about the IAC?
The inside of the distributor was rusty and crusty, I couldn't ever recognize the screws that held the ignition module on so I just decided to replace the entire unit and return the ignition module.  That was not the issue either.  The IAC tested within the voltage parameters in the testing procedure.  Even though the Platinum plugs looked great I changed them and that was the problem all along
« Last Edit: June 18, 2021, 02:38:04 pm by zieg85 »
« Reply #18 on: June 18, 2021, 03:07:38 pm »
...  Even though the Platinum plugs looked great I changed them and that was the problem all along
Wow that is both sad and encouraging..  All came down to plugs
Offline MIKE S
  • Member
« Reply #19 on: June 18, 2021, 03:13:05 pm »
Did you change the gap on the platinum plugs? You can't run a gapper between the electrodes on a platinum or iridium plug. Even the slightest amount of drag will disturb the platinum and could have caused your problem.
« Reply #20 on: June 19, 2021, 12:25:54 pm »
Quote
Please don't say you used Bosch Platinum's  :o
« Reply #21 on: June 21, 2021, 01:06:35 am »
Quote
no but that was what was in it.  Put some AC non platinum
« Reply #22 on: June 21, 2021, 06:30:13 am »
Quote
They are absolute garbage
« Reply #23 on: June 21, 2021, 08:38:51 pm »
Quote
Good to know...  I got about 150 miles down the road and my service engine light came on and went off.  Truck started bogging real bad and barely made it safely to a parking lot where my son came and got me with a uhaul dolly.  Anyway my brother in law came with an OBD1 scanner.  All tests pointed to the MAP sensor.  Changed it and that wasn't it.  I really don't know where to turn.  He is going to do some checking tomorrow and see if he can come up with something else.
Offline Asphalt Dr
  • Parking lot cosmetic surgeon
« Reply #24 on: June 21, 2021, 09:10:41 pm »
Have you checked the fuel filter?
87 r10 swb 350 th350 LS coming soon!
« Reply #25 on: June 21, 2021, 09:47:05 pm »
New fuel filter less than 250 miles ago
« Reply #26 on: June 21, 2021, 11:40:42 pm »
Before drifting too far afield, verify the fuel pressure.
« Reply #27 on: June 22, 2021, 10:34:59 am »
Some run time data, weird voltage reading and re-ac curing code 42 and 44 with the known history of the truck are pointing to wiring based on a very similar situation reported on a mechanics resource my brother in law sent me to try.
« Reply #28 on: June 22, 2021, 11:40:48 am »
This is the Diagnostic for 42:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=36657.msg308237#msg308237
44 means lean so I too say check fuel pressure.  What does the TBI regulator look like.  I had one with a broken spring...
« Reply #29 on: June 23, 2021, 05:58:44 pm »
Put the parts cannon away. Check the basics, fuel pressure, proper timing set, and preliminary checks before you buy parts.
