Author Topic: Flexing of metal at door handle  (Read 5504 times)
Offline MY1978
  • Just a girl and her truck since 1978
« on: June 27, 2021, 06:29:05 pm »
 Hello all.  I have noticed that the metal on the door at the door handle small end (opposite of the push button) flexes a little.  It doesn't happen on the passenger side.  I will attribute this to the fact that due to that door being used more (as in by me!   ;D)  and the pulling on it over 43 years is has caused the issue.  Is there some way to support this?
Thanks
Re: Flexing of metal at door handle
« Reply #1 on: June 27, 2021, 09:55:42 pm »
There is a reinforment plate behind the door handle, it is detached?
Offline fitz
« Reply #2 on: June 30, 2021, 04:03:01 am »
Is the drivers side door an aftermarket replacement?
Offline MY1978
« Reply #3 on: June 30, 2021, 07:11:17 am »
Not an aftermarket door - is original door with reinforced plate.
Offline Mike81K10
« Reply #4 on: June 30, 2021, 08:20:07 pm »
You have to take your door panel off and get a look inside your door to inspect it. Only way to find out what is going on.
Offline MY1978
« Reply #5 on: June 30, 2021, 09:17:06 pm »
Already done that.  Door panels are off and awaiting new panels.
« Reply #6 on: July 01, 2021, 07:05:45 pm »
So is that loose in any way?  Depending on your definition these trucks were not designed to be perfect. and there is flex in that panel area.
Offline Mike81K10
« Reply #7 on: July 01, 2021, 07:13:40 pm »
Looks OK! Check for any damage and then your could cut a 12 or 16 gauge piece of sheet metal about 2" 4", drill a hole for the door handle screw(s) and reinforce the door panel if you cannot find anything wrong. Might help!
Offline MY1978
« Reply #8 on: July 02, 2021, 06:49:48 am »
The plate is not loose and the bolt is definitely tight.  The outer skin, at that bolt, is where the flexing is happening.  This has happened over time.  Passenger side does not flex.  I am going to try putting a large fender washer behind bolt to see if that helps stiffen things up.
Offline MY1978
« Reply #9 on: July 02, 2021, 01:54:45 pm »
Okay.  I fixed it.  From what I can figure out, the "reinforcing place" is not flat against the outer skin thus causing some flexing.  Using a large fender washer did not help.  So...........I took a 4" mending plate and pushed it long ways up under the lower lip of the plate and voila!!!!  No more flex.  Since the plate is not removable, I used a generous amount of some Gorilla glue along the top edge towards the outer skin.  Once that is cured, I can go back and apply some epoxy along the bottom edge so it doesn't fall out.   HEY!!!!  What ever works!!!!!!!! :D :D :D :D :D :D :D
