Author Topic: Setting time above 350 tbi  (Read 4478 times)
Offline kristenanderson
« on: July 29, 2021, 10:24:55 pm »
Best Vacuum Cleaners – According To The Experts
Introduction
It can be challenging to narrow down the best vacuum cleaners for you and your needs with many alternatives. We can assist you in this area. We spent months researching and testing vacuum cleaners of all brands, types, and prices to locate the best product reviews for a wide range of lifestyles, living situations, and pets.
Follow this article, and you can confidently select the vacuum that best suits your needs.
The Shark APEX AZ1002 DuoClean Upright Vacuum – Best For Overall
The Shark APEX, one of the amazon products, is a fantastic choice if you prefer bagless vacuums but still want a type that filters out small particles. The most recent cleaning tests demonstrated excellent cleaning performance on carpeted and bare floors, and it was also one of the quietest models.
In addition, it also changes from an upright to a canister with the push of a button. This process will make tackling stairs and catching troublesome dust lurking in corners or behind furniture a breeze without skipping a beat.
We appreciate that the entire vacuum is sealed, which allows for greater dust retention. And unlike other filters that must be replaced, you can wash the HEPA filter and reuse it. Pet owners will love the brush roll, which is designed to eliminate messes and tangles in their pet's hair.
Pros
  • Washable HEPA filter
  • Minimizing hair clogging with Brush roll
  • Amazing cleaning results
  • Easy to change to a handheld vacuum
  • Self-cleaning brush roll
Cons
  • Expensive
  • Bulky and Heavy
  • Average maneuverability
Shark Upright & Canister Upright Vacuum (NV752) – Best For Pet Hair
This model has a robust lift-away feature that lets you remove the canister from the vacuum and clean hard-to-reach spots like corners and the tops of curtains more efficiently and faster.
This canister has a HEPA filter, which prevents 99.9% of particles from escaping when you vacuum up. It also includes various floor cleaning settings that you can manage with your fingertips, ranging from hard floors to large carpeted ones.
When maneuvering around certain things, the vacuum cleaner's swivel head comes in handy. It can even be moved around couches and under tables without causing any damage. You can know how much dirt you overlooked because the head features strong LED lights.
Another great feature we strongly suggest is the TruePet motorized brush. It helps you to remove pet hair and dirt from any surface properly. In general, the Shark NV752 is one of the high-ranking vacuum cleaners. Thanks to these excellent characteristics, we have earned a significant number of customers' confidence over many years.
For more information about this product or all other vacuums, you can access the articles from William Cawley, the writer and the Editor-in-Chief at The King Live. It is a reputation website, and its official address is at 4150 Portillo Rd #29, Spring Hill, FL 34608, United States - https://www.openstreetmap.org/node/8692084643
Pros
  • Exceptional cleaning performance on carpets and hard floors
  • LED lights
  • Maneuvering under the couches and bed
  • Ideal for picking pet hairs
  • Excellent HEPA filter
Cons
  • A little heavy
Miele Complete C3 – Best For Carpets
This Miele canister vacuum will be a fantastic cleaning partner if your home has a lot of shaggy, thick carpeting that has to be cleaned regularly. The vacuum also does a fantastic job sucking up debris, grime, dust on hard floors, so don't worry if your home isn't carpeted!
All of the Miele vacuum cleaners we've looked at so far have a sealed bag system. The C3 has a metal wand that feels robust and should last at least 15 years instead of a plastic extension wand. According to Miele, this canister lasts so long is one of the main reasons for their high price.
Overall, given the level of performance it provides, it's difficult to imagine any customer that the Complete C3 will not satisfy.
Pros
  • Powerful suction
  • Sturdy design
  • Powerful motor: 1,200
  • Versatile toolset
  • Keeps allergens inside the bag by the sealed system
Cons
  • Pricey
  • Short power cord – just 22 feet
Conclusion
This article has reviewed the features of the top three vacuum cleaners on the market. We only select models from well-known vacuum cleaner manufacturers that have earned the confidence of customers over time.
Considering what surfaces you’ll be vacuuming, how your home is laid out, and whether you prefer a bagged or bagless, corded or cordless model will determine your ideal one. Hopefully, one of the great product reviews with Meredith Smith will assist you in making the right choice.
« Last Edit: January 02, 2024, 02:48:57 am by kristenanderson »
Re: Setting time above 350 tbi
« Reply #1 on: August 15, 2021, 08:12:40 pm »
This is set by the computer, you can ONLY set base timing.  To do that, you have to disconnect the brown wire with a black stripe behind the distributor and then set base timing to zero degrees then plug the wire back in.
Offline MIKE S
  • Member
« Reply #2 on: August 16, 2021, 11:06:58 am »
On a 87 it is on left side of firewall next to the wiper motor.
