Engine/Drivetrain
Need Help Swapping 6.0ls with 4l80e in 82
Topic: Need Help Swapping 6.0ls with 4l80e in 82 (Read 2976 times)
Vasbinder
New Users
August 10, 2021, 02:36:18 pm »
What are the best engine mounts and cross Member to use for this swap. Can I run the factory A/C location on the L.S?
Last Edit: August 10, 2021, 06:24:52 pm by Vasbinder
Re: Need Help Swapping 6.0ls with 4l80e in 82
August 15, 2021, 07:03:22 pm »
If you are talking aftermarket I would personally look at
Holley's C10 swap
kit or
Tejas Steelworks
Tejas using the factory LS access drive with AC but moves the engine forward 3"
you can use swap plates and then modify the passenger side frame stand and move it back to make room for the AC in the factory location. this is one from a fellow 73-87 owner on Josh's page:
http://67-72chevytrucks.com/vboard/showthread.php?t=413855
Engine/Drivetrain
