Author Topic: T56 Magnum?  (Read 2730 times)
Offline NTDYNA
T56 Magnum?
« on: September 29, 2021, 07:30:45 pm »
Anyone does this swap? Preferably behind a Big Block, I contacted American Powertrain. Got a quote of 6500ish,that's all new every from a steel bellhousing, single disk clutch, hydraulics, clutch pedal assembly, flywheel and all the electronics to convert the electronics to the mechanical Speedo.
I'm thinking I could peice together most of it a lot cheaper though, I THINK a LS and SBC/BBC have the same bolt pattern on the bellhousing so I could take a bellhousing off a Fbody, maybe Fbody hydraulics. I also wouldn't be opposed to putting a mechanical clutch in it.
-76 Short Bed 454-
