Author Topic: Looking for original quadrajet for 1977 C10 350  (Read 15727 times)
Re: Looking for original quadrajet for 1977 C10 350
« Reply #15 on: October 30, 2021, 07:22:30 pm »
Convert to fuel injection instead of dumping your money into a crappy rebuilt Q-jet.
Offline Steppin Razor
« Reply #16 on: October 31, 2021, 04:21:18 pm »
The fuel metering block may be warped.  Not an uncommon problem, generally the result of over-torqued fuel bowl screws.  New gaskets often hold for a few thermal cycles but then begin to bypass and leak.  If metering block warpage is the case, the block can be straightened in a press with careful application of pressure.  The blocks are soft and distort easily.  Fortunately, they also can be repaired fairly easily.
Good to know, thanks.  I ended up getting an Edelbrock 1906, but I'll take the Holley apart again and see if this was the case.  If it was, I'll fix it and at least get a few bucks for it.
Unfortunately, I couldn't afford to do that.
« Reply #17 on: October 31, 2021, 07:14:12 pm »
Spending $500 on a junk rebuilt Q-jet, you're more than half way there. You'll save in the long run. https://www.summitracing.com/parts/fif-30003?seid=srese1&gclid=EAIaIQobChMIvLydkbDz8wIVymtvBB2gBQ8TEAQYASABEgIRffD_BwE#recommended
Offline JohnnyPopper
  • Old Goof
« Reply #18 on: November 01, 2021, 12:56:22 am »
WOW looks impressive! Does it meet California's smog requirement?
Funny thing they allow 300 ppm for these trucks!!!
1980 C-10 under construction
« Reply #19 on: November 02, 2021, 06:01:02 pm »
300 PPM of what?
  • Old Goof
« Reply #20 on: November 02, 2021, 06:31:53 pm »
300 PPM of what?
I don't know VZ, the bad stuff??? In Cali it could be 300 ppm of squirrel poop! Seriously!
Pry Nox...
