Author Topic: clanging noise?  (Read 4718 times)
Offline lowc10
clanging noise?
« on: January 28, 2007, 10:26:00 pm »
i have a 85 swb with a th350, the trans was built to last me along time but you know how that can go. So just lately it started making a clanging noise when you put it in gear, the faster you go it goes away. But it is there for a few seconds when you take off sometimes. Think it's the u joints?
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: clanging noise?
« Reply #1 on: January 28, 2007, 10:11:00 pm »
First thought in my mind is ujoints...easy to check.  Throw her in neutral after blocking the wheels and get up under and play w/ driveshaft and see if the joints are loose.
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
Offline chevyfan
Re: clanging noise?
« Reply #2 on: January 28, 2007, 11:13:00 pm »
i recently had a clanging noise also and it turned out the tourqe converter was loose on the flywheel, the clanging noise only showed up at low rpm, and at higher rpm the noise was gone
Re: clanging noise?
« Reply #3 on: January 29, 2007, 06:02:00 am »
I agree, sounds like the torque converter or flywheel is lose.
Offline lowc10
Re: clanging noise?
« Reply #4 on: February 02, 2007, 07:26:00 pm »
well it doesn't clang but when you back up and give it gas it clangs and stop and then go agian it will clang. When you start going it makes a squeeling pinging kinda noise for a little bit then goes away. I just got some new u joints from summit yesterday. So you think it's the verter or flexplate?
