Author Topic: 1987 Silverado V10 from the frozen north  (Read 219180 times)
Offline Shifty
  • I bleed Bowtie red...
Re: 1987 Silverado V10 from the frozen north
« Reply #75 on: May 01, 2023, 11:14:48 am »
Rompin', stompin' Mickey Thompson!   100% would hoon the heck outta that!
98 C2500 ext cab longbed
Offline JohnnyPopper
  • Old Goof
« Reply #76 on: May 01, 2023, 12:19:39 pm »
Looks great!
Great stance!
« Last Edit: October 01, 2024, 04:33:53 pm by Captkaos »
1980 C-10 under construction
  • Old Goof
« Reply #77 on: May 01, 2023, 02:00:23 pm »
A hoon is an Australian term describing a person who deliberately drives a vehicle in a reckless or dangerous manner, generally in order to provoke a reaction from onlookers.. Hoon activities (or hooning) can include speeding, burnouts, doughnuts, or screeching tyres. Those commonly identified as being involved in hooning are young and predominantly male drivers in the age range of 17 to 25 years.
Sounds like most of us here, at least at one point in our lives. 8) ;D :o
« Last Edit: May 01, 2023, 02:42:30 pm by JohnnyPopper »
Offline Shifty
« Reply #78 on: May 01, 2023, 02:22:19 pm »
Guilty...(except the age bracket) ;)
Offline nbarr7
« Reply #79 on: August 04, 2024, 02:59:12 pm »
It has been some time since the last update, but things are actually progressing. Most notably I took the bed to a local body guy (an old stoner who works out of his garage - maybe not museum level work, but I dont' pay museum prices, and I kinda like old characters) and he repaired the bent in spots, and put a first coat on it. I hadn't been driving the truck with the bed off, and it had been raining every other day in MN here anyway (and I don't have inner fenders in yet) so after the bed got one coat I finally put it back together:
1987 Silverado V10 Fleetside
2002 Silverado Extended Cab Z71
1975 Corvette Stingray
Offline nbarr7
« Reply #80 on: November 03, 2024, 11:40:53 am »
Well, work on the cab ended up being more extensive than anticipated. I brought it in for rockers/cab corners and as is expected I suppose with a MN truck, the floor under the drivers side was rusted out decently, including the cab support. So... a new floor on the drivers side went in, as well as re-=bracing the cab support, and etc.
Then, not knowing exactly how this all worked, I'm informed it's best to have the doors so you can weld the rockers to line up with the doors, so... I picked up a new driver door from a junkyard, and the passenger door was mudded (this is a driver resto not a museum piece as I believe I've said). Finally rockers and cab corners start getting addressed.
Offline nbarr7
« Reply #81 on: November 03, 2024, 11:48:51 am »
Once the rockers started going in, we also needed to match the gaps with good fenders, so... had to snag on a brand new second hand pair of front fenders. But... they weren't hanging right as it turns out the core/rad support was too rusty. Turned out to also be the core support mounts on the frame, so new mounts got welded on, brand new core support, and finally got fenders on it to line up rockers and door gaps. As long as we were in there, I got new inner fenders (old ones were totally rusted out) and battery tray. We also painted the frame by the motor as long as all the fenders were off.
« Last Edit: November 03, 2024, 12:02:15 pm by nbarr7 »
Offline nbarr7
« Reply #82 on: November 03, 2024, 11:59:38 am »
So what began at the body shop as rockers/cab corners became new driver floor, new cab support, new core support, new core support mounts, new(used) fenders, new inner fenders, and random stuff like new door strikers, hinge pins, new tailgate, new tailgate handle/some hardware... It became a kinda brand new truck parts-wise without that being the plan just yet, but once we were in it, it just made sense to keep going. Finally, we got to paint. This is obviously a local/garage kind of job, and the body guy has been real cool about all of this and not going crazy with price. So after a basic spray (pre-buffing dust out) she finally is black again! Had to take the visor off for rust addressing and paint, so while we did that, I also had a new (used) windshield installed, and had a rear slider put in (since I dig those). It's coming along...
*sorry for multiple posts - just updating a lot of info and trying to keep it sorted.
Offline nbarr7
« Reply #83 on: November 03, 2024, 12:29:11 pm »
The truck finally got moved outside and saw its first daylight in quite a few months. Just in time for fall storms and branches falling, but luckily has thus far escaped harm. With expanded room to work, I finally got the floor a bit sorted, cleaned things out and put some butyl sound deadening under the carpet, and put the carpet back in. We also put the visor back on backed by some caulk around the screw holes in the roof. Got to address some chrome trim here and there, and a host of tiny things (new headlight adjusters etc since the old ones were so rusty/brittle they didn't adjust) or painting the metal headlight buckets. It should take a little to clean up all the loose ends, but I'm trying to get it home soon finally!
Offline Shifty
« Reply #84 on: November 04, 2024, 08:49:43 am »
I like it!
  • Old Goof
« Reply #85 on: November 04, 2024, 02:51:48 pm »
Nice work! Congrats for sticking with it.
Offline nbarr7
« Reply #86 on: July 14, 2025, 07:16:42 pm »
I get behind updating things here. Like was suggested, oil pressure was just a gauge malfunction. It drives great.
That said, since November I have put much of the interior back together, after adding some sound dampening to the floor under the carpet. I re-sprayed/dyed burgundy some eBay door cards (my body guy broke both mine) and got new carpet lowers (old owner cut speaker holes). Replaced all the window gaskets, and now am looking to replace the frame on the passenger smoker/vent window - just have to find my rivet gun before drilling it out. Got a new repro rear bumper, and a rust-free front bumper. Re-spray painted the headlight bezels silver for clarity. Added a new bed bolt kit, so that's locked down now. mud flaps (minor) What else have I done...? New side trim, emblems, fuel injection emblem (my original one on the new repro tailgate!) Lots of odds and ends etc. Still need to do the headlienr, but I'm driving this thing this summer! Already put over 100 miles on it in the last few weeks (I live in the country, so everything is at least 10 miles away ha).
Got some tubby steering, but I haven't yet replaced tie rod ends etc, so likely I'll do that soon-ish. But for now, I'm putting the miles on enjoying it!
Offline Shifty
« Reply #87 on: July 15, 2025, 11:47:02 am »
heck yeah!  8)
  • Old Goof
« Reply #88 on: July 16, 2025, 11:02:49 pm »
Love it when a plan comes together! Congrats!
