Author Topic: 1987 Silverado V10 from the frozen north  (Read 226468 times)
Offline nbarr7
Re: 1987 Silverado V10 from the frozen north
« Reply #60 on: May 30, 2022, 06:54:44 pm »
Ok. I will post a video later, but my check engine light is on (if I hold it with a finger) before startup, and then goes off during startup. I disconnected the negative side of the battery for over 5 minutes and cleared codes. I then ran the truck for 1-2 minutes. Jumpered the obd port, and my check engine light gives me 1-2 over and over, which I read 12 is the start and end of any code sequence, so unless I have an error code of 12, it's giving me no ecm codes currently. The truck is seeming to run a little better, but still has a weird start.
I'm renting a fuel pressure test kit from O'Reiley's in the morning so I'll let you know what I get for a reading there.
1987 Silverado V10 Fleetside
2002 Silverado Extended Cab Z71
1975 Corvette Stingray
Offline nbarr7
« Reply #61 on: May 30, 2022, 09:02:09 pm »
Just to avoid any misinterpretation (on my part in how I describe things) here's some video clips of how I checked ecm codes and how the truck is currently starting/running. Fuel pressure test coming tomorrow still.
https://youtu.be/s553Rz0etA8
« Last Edit: June 01, 2022, 10:45:08 am by nbarr7 »
Offline nbarr7
« Reply #62 on: May 31, 2022, 01:04:31 pm »
Rented a fuel test kit this morning. The pressure goes up to maybe 10-11 psi when you first turn the key on, but dwindles after the pump shuts off. Pressure goes back up to about 12psi when the truck is running. Seems constant at this pressure. Once truck shuts off and pump is turned off shortly after, pressure drops back to zero. Here's a video showing the process and hearing/seeing it in real time so to speak. I know the gauge is higher than needed, but it's the only kit O'Reiley's had, and living an hour outside of Minneapolis, I only have so many options.
Fuel pressure video from this morning:
https://youtu.be/w8K2AVJL24s
« Reply #63 on: June 01, 2022, 02:32:32 pm »
Code 12 is an ignition "tach" signal code that is normal whenever the ignition is switched ON with the engine not running.  It is a volatile code that will not store in memory and does not indicate a problem.
Running TBI fuel pressure should be about 12 PSI.  So, the running pressure appears normal, although it should maintain about 7 PSI for several minutes after the ignition is shut OFF, suggesting minor internal leakage through the pressure regulator or fuel pump.
Verify the spark plug wire firing order 1-8-4-3-6-5-7-2.  Remove the passenger side spark plugs and keep them sorted in order and labeled from front (cylinder #2) to back (cylinder #8).  Make sure none of the ceramic insulators are cracked and then post a clear closeup pic of the electrodes as they were removed from the cylinders.
Wipe the fuel injector tips (nozzles) with a clean rag.  Slip a piece of clean, dry paper towel below each injector, directly above the throttle plates, and cycle the ignition key ON and OFF without cranking the engine.  This will momentarily energize the fuel pump and build fuel pressure.  Inspect the paper towels for wetness to see whether the injectors are dribbling any fuel.
Have you run a cylinder compression or leak-down test?
Offline nbarr7
« Reply #64 on: June 01, 2022, 03:54:32 pm »
Before I saw this reply about testing plugs etc, I had a little bit of downtime at work so I attempted to time the truck.
Please note I have never timed a car, or even held a timing gun until today, so... I'm learning. Bear with me.
The short story is that the timing was way advanced, I believe (?) and I was able to get a stable timing read with the ecm bypass unplugged. I eventually got the timing to what I believe was zero. Low idle, but running smoothly all things considered. I then disconnected the negative terminal on the battery for 15 minutes, reconnected the ecm bypass, reconnected the negative battery terminal, and tried to start the truck. Ran horrible - backfiring and not even staying running. Checked for ecm codes, and still only have 12 over and over. Here's the video:
https://youtu.be/HP39iIEvRzk
« Reply #65 on: June 01, 2022, 05:18:01 pm »
Seeing as how the ignition timing seems all wonky, you should verify that the outer ring of the harmonic balancer hasn't slipped, altering the position of the timing mark with respect to the crankshaft.  If the balancer has slipped, you will never get an accurate timing adjustment.
Remove all of the spark plugs, keeping them in order by cylinder number.  Bump the engine over using the starter until the #1 cylinder barely begins to build compression.  With help from an assistant, bar the engine clockwise by hand (from the perspective of looking at the engine from in front of the radiator) until the #1 piston just reaches its peak upward travel before reversing direction.  You can closely approximate piston position either by peering through the spark plug hole as the piston is moving or by feeling the top of the piston using a thin probe inserted through the spark plug hole.  Once the piston has exactly peaked in its cylinder, look at the timing marks to determine whether they align at zero - they should.  If the marks do not align at zero, the outer ring has slipped to the extent of the visible separation and the balancer should be replaced.  There are other methods, but this should work for you in the field; pun intended.
BTW - This does not negate the other checks and procedures recommended thus far.
Offline JohnnyPopper
  • Old Goof
« Reply #66 on: June 01, 2022, 08:21:15 pm »
Not so frozen now we see... ;D
bd is right, check that you have a stable balancer before anything else.
If you're off mechanically you will be chasing the wind.
1980 C-10 under construction
Offline nbarr7
« Reply #67 on: June 03, 2022, 09:13:45 pm »
I will recruit my wife to help this weekend with checking the harmonic balancer positioning relative to tdc.
In the interim, I am addressing some electrical gremlins, since electrical is closer to my comfort zone. My fuel gauge now works (it had never worked since I got the truck) and I realized the issues with the brights indicator being on and my temp and oil pressure gauges suddenly not working was the copper stripping around the back side of the clock side of the dash especially, had gotten somewhat bent from removal/install/removal of the dash cluster (both from previous owner and me) and the ground strip and one other piece were actually severed in one place. So, delicately soldered and checked continuity on those and I have a fully working dash (except the clock is really hard to set since the post/twisty thing is bent and corroded). I even have a dome light suddenly when turning the lights knob all the way counter clockwise!
I've been reading pinout diagrams and wiring charts (what I have access to via google anyway) and am wondering if someone could provide a comprehensive list of where I should have grounds on this vehicle? It's a big ask, so I'll start with what I know, and maybe someone can fill in the blanks...
Battery negative is grounded to the frame, drinker's side engine bay, which is connected then to the alternator bracket. I also have a ground next to the thermostat. I do have continuity between the body and neg/bat, so the body ground appears to be working . I have verified gas tank/fuel pump is grounded in both send/return lines and the separate frame ground. I've found and verified the ground for the dash cluster at the plug as well as the system grounds at A12 and D1 at the ecm plug. I've verified o2 ground at D6 and crank sensor at C9 on the ecm plug. I do NOT have a ground for D2 or "Map Ground" but looking at the wiring diagram, it maybe seems like I shouldn't? I'm basically trying to find if I have a short to ground in any circuit I shouldn't kind of thing. Or vice versa, if something isn't grounding out and not completing the needed circuit. I'm also getting a very small spark when I re-connect the negative to the battery, so something is drawing or grounding.
« Last Edit: June 03, 2022, 10:00:41 pm by nbarr7 »
« Reply #68 on: June 04, 2022, 12:55:33 am »
All of the GM factory manuals are available in our Technical Forum \ General Information and Maintenance \ 1973-87(91) Factory GM Pickup Manuals
Basics: Vehicle Ground catalogs the major ground points that are shared by all of the 73-87(91) squarebody trucks.  For application-specific grounds, you will need to reference the appropriate year factory wiring manual.
Sparking at the battery is common.  To determine whether it is significant, measure the current draw using a proper ammeter.
FYI - Ground connections should be validated by voltage drop, not by resistance (continuity) measurements.  Even minuscule resistance can prevent the proper functions of moderate to high current circuits (e.g., arbitrarily, greater than ~2 amps).  Most ohmmeters are not sufficiently sensitive to accurately measure such small resistance.
Offline nbarr7
« Reply #69 on: June 04, 2022, 10:05:55 am »
Super helpful. I apologize I didn't find those resources earlier. Google doesn't suggest them as readily as other forums and resources apparently. Thank you.
« Last Edit: June 04, 2022, 10:10:33 am by nbarr7 »
Offline nbarr7
« Reply #70 on: June 04, 2022, 10:46:44 am »
In inspecting the harmonic balancer, I found my coolant leak. Unfortunately it looks like it's coming from the bottom of the water pump. I'm assuming that's shot then. Makes sense why I'd lose coolant worse after driving (why I was afraid of a head gasket way forever ago).
Offline nbarr7
« Reply #71 on: July 24, 2022, 11:07:19 am »
Hello all. While this is NOT the end of the story, I wanted to officially post the process of my fighting with the esc bypass so others can see what I was experiencing.
Synopsis for those not wanting to watch:
After timing the truck as documented in this thread, I tried adjusting timing 10 degrees advanced and retarded to account for any slippage in either direction by the harmonic balancer. Truck ran fine with the ecm bypass disconnected but ran like absolute garbage as soon as that wire was plugged back in regardless of advanced or retarded turning of the distributor. Over and over, no matter what I did truck ran fine in base mode, and basically didn't run (backfiring/rough not staying running) as soon as I tried to get the ecm to control advance. I had my wife help me find tdc, and harmonic balancer didn't seem too off. Based on other forum posts here and other places, people describing the ecm bypass wire issue I was having usually traced it back to some portion of the distributor. So... I took mine out to replace the pickup in there. I disassembled it, and cleaned it, and replaced the pickup and the reluctor (since I broke the reluctor getting the stuck parts apart) and then I had a wonky time getting the distributor to clock right when I reinstalled it - even though the truck had not moved, nor had the engine turned. I still don't actually know what was going on there. So, ultimately I decided to get in-person help and a local mechanic took it to his place to get to the bottom of things. Next update will document that progress, but this is the (late) video update for LAST month.
https://youtu.be/NgPv6_qhlVY
*Be aware I'm not asking for advice for this video, since actually most of this is rectified now -not by me - but that update is to come once I get the truck back.
« Last Edit: July 24, 2022, 12:36:29 pm by nbarr7 »
Offline nbarr7
« Reply #72 on: August 11, 2022, 08:29:04 pm »
Well, we have made progress on the ECM issue. I have a video explaining it, and chronicling the current month progress on my truck.
https://youtu.be/TlnykKS6tSY
Note in the video that my local mechanic also had a new bed, so it's now sporting a surface-rust blue box.
Also, it seems like I'm replying to myself mostly on this thread by now, so if this is uninteresting to you all and you have suggestions as to how to make it more engaging, let me know. I don't mean to just take up digital space. Hoping to kind of take you guys with me as I learn, and as this truck gets slowly better and better.
*for the TLDR folks so to speak, to summarize the video, the truck is now home and runs. The ECM issue could have been a few things, but a wire was found to have pulled slightly out of the harness going into the ignition control module. I thought I had checked for shorts in all 4 of those wires but who knows. I very obviously miss things. An entire new distributor was also put in, so that could also have helped as well. Either way, if anyone is having that problem of only running well in base timing mode with the bypass circuit unplugged, it seems to generally be related to the distributor, or wires thereto.
Next up, I'm looking into tires and new springs, and some general bushings and etc to get us riding a little smoother...
Offline nbarr7
« Reply #73 on: September 26, 2022, 10:49:51 am »
It's been a little bit, but there is progress on the truck. I replaced the water pump (and radiator hoses) and I no longer seem to be losing coolant. I also had a decent fight with one of the rear wheels that was all but welded on with rust/friction, but finally prevailed, and the truck is now sporting some 33" tires I found around here used for cheap. I'd eventually like to re-wrap my rally wheels with beauty rings etc, but for now these work since they came with the rims they're on. So at this point, I believe I have an unequivocally running and driving truck. Which is where I wanted to be a year ago, but I've fixed an awful lot in this past year as well, so I shouldn't complain.
As it's advancing toward winter here in Minnesota, I likely will not do as much on the truck at this point, since I don't plan on driving it winters. That said, one of my next moves is addressing sacked out suspension. I think with these 33s (that somehow don't rub at all currently) I'm going to look at 2" lift springs, and do some shopping for correlating shocks. With this not being a work truck, I wouldn't mind the ride being smooth-ish, and I've heard good things about e-z springs, and I may go that way.
Offline nbarr7
« Reply #74 on: May 01, 2023, 11:09:49 am »
It's been a, well, a frozen northern winter. Which I love, but having an unheated shop doesn't lend itself to truck progress. With spring tentatively arriving, however, projects once again are underway on the 87. Most recent is an e-z ride based 2" spring lift (blocks in back) to improve ride and look just slightly better. Shock towers were painted black, since we're keeping things simple on this guy. I've never lifted anything, and had a friend help with front disassembly, but kind of just figured things out as I went (and asked friends a LOT of questions). I still need to buy new rear leaf springs as the kit only came with fronts (why I suspect she's down at the rear slightly) but she's ever so slightly coming along...
