Author Topic: TH400 swap opportunity?  (Read 6842 times)
Offline krigermoose
  • 1986 GMC C1500 5.7L
« on: January 08, 2022, 01:59:20 am »
Hey everyone, long story short I bought a used 350 to drop in my truck after mine blew. This new 350 also happens to be mated to a th400 and the guy wanted to just sell the whole package. It came from his daily driver '75 c20 that he just pulled the engine and trans to drop in a ls 6.0/4l80 setup. Supposedly the th400 has less miles than my truck's th350, and they are most likely in similar condition.
Would it not be a bad idea to just leave the th400 on the engine and drop it all in? Will I need a new driveshaft as well?
Offline dusterdude
Re: TH400 swap opportunity?
« Reply #1 on: January 08, 2022, 05:29:26 am »
I would,but you'll at least need a 400 input for your driveshaft or maybe a whole new shaft depending on length differences
Sent from my SM-G973U1 using Tapatalk
« Reply #2 on: January 08, 2022, 09:12:44 am »
Be mindful that the TH400 kickdown on squarebody trucks is an electrical switch on the go pedal under the dash.
Offline krigermoose
« Reply #3 on: January 08, 2022, 01:31:24 pm »
I'm considering if it's worth getting a new driveshaft because I'm fairly certain the two transmissions are difference lengths. And regarding the TH400 electrical switch, is it simple to bolt up?
I also do not know for sure if I can mate the old TH350 to the new 350 without a new flex plate? Or can I just bolt it up?
Offline JohnnyPopper
  • Old Goof
« Reply #4 on: January 08, 2022, 02:29:54 pm »
the TH400 is certainly step up in many ways, but I would consider the benefits vs the costs.
A TH350 is plenty good for most trucks, so a couple of questions:
Is your use of the truck in need of a stronger trans?
Do you race?
Haul?
Pull out stumps?
If none of the above, I would keep my life simple and sell the TH400.
1980 C-10 under construction
Offline krigermoose
« Reply #5 on: January 08, 2022, 03:06:35 pm »
Yeah I don't plan on doing much pulling, racing, etc. I also don't necessarily know the lifespan of my th350 since it sat for at least 10 years.
  • Old Goof
« Reply #6 on: January 08, 2022, 06:33:03 pm »
10 years of no wear.  8)
Change the front seal while it's available.
The dipstick seal.
Rear as well.
The trick to these is to keep them clean, they will go forever.
Offline krigermoose
« Reply #7 on: January 10, 2022, 10:39:47 am »
I like your thinking. I'll giver a look.
Offline Shifty
  • I bleed Bowtie red...
« Reply #8 on: January 10, 2022, 11:06:42 am »
While heavier-duty from a stock standpoint, they are also heavier, and require a bit more horse to drive than a TH350.  For a few dollars, you can address the weak point of the TH350, the intermediate sprag....change it out for a hardened 36 element one, and have your cake and eat it too.
98 C2500 ext cab longbed
Offline krigermoose
« Reply #9 on: January 10, 2022, 06:22:55 pm »
Right on, good to know. I'm assuming the engine bolted to the TH400 doesn't need anything to bolt to a TH350? If it needs a flex plate I've got one.
Offline Shifty
« Reply #10 on: January 11, 2022, 08:08:45 am »
Most likely, it'll all bolt up, as long as it is the earlier flexplate, you know, 2-piece rear main seal engine, etc...
  • Old Goof
« Reply #11 on: January 11, 2022, 04:28:22 pm »
Same bolt pattern since 1955... 8)
Offline krigermoose
« Reply #12 on: January 12, 2022, 02:47:13 am »
My truck's old engine/trans setup was '86, this new one is '75. Still seems fine though.
