Author Topic: Lowering spindles  (Read 18176 times)
Offline Cheyenne1010
Lowering spindles
« on: January 17, 2022, 03:31:09 am »
My name is Robert and I own a 1973 Chevy C10 Cheyenne long bed and i got a frontend lowering question.ive seen all the different lowering kits on the market and my question is can I use my stock coils with a drop spindle?my understanding of a drop spindle is the shaft that the brake rotor bolts on to is raised.so can I use stock coils with drop spindles?(im looking to lower it just a little bit,not trying to slam it on the ground)
Offline LILT77
Re: Lowering spindles
« Reply #1 on: January 17, 2022, 12:21:45 pm »
Yes, you can use the spindles with stock springs...but most people would do the springs first before the spindles. Springs are cheaper
77 C10/Big 10 Cheyenne "Old Blue"
81 C2500 Sierra Grande "Gramps"
« Reply #2 on: January 17, 2022, 03:34:28 pm »
Thank you for the information and for the reply.now I can do the install and see how it looks.
         Thank you for your time
« Reply #3 on: January 24, 2022, 07:36:52 pm »
Using spindles first won't change the way it rides, it will be exactly the same except lower.
Keep in mind the rear will be higher and the truck much more raked.
Offline JohnnyPopper
  • Old Goof
« Reply #4 on: January 24, 2022, 09:09:09 pm »
Cheaper yet is to cut your existing coil springs by one or tow circles.
1980 C-10 under construction
Offline Chevynut73
« Reply #5 on: July 03, 2023, 09:06:03 am »
I have pretty much the same Truck as Cheyenne 1010 and wanting to lower mine too - is cutting the existing coils a little as good as buying new ones?
I figure the 50 year old original coils have sagged some maybe - which ain't a bad thing ???
'73 Chevy C10, 350, TH350, was a long Fleetside, now she's a short Stepper that's under construction (been in the Family since 1972).
Would rather push a CHEVY than drive a Furd
