Author Topic: Body lift, raise fuel tank?  (Read 4936 times)
Offline Dieselfume
« on: January 24, 2022, 07:45:38 pm »
I purchased a 2" body lift for my '87 R-10 (PA-522 as an enabler for future mods (to get a 2wd cab to clear a transfer case). Heard that 2" would get the t-case to fit, but 1" wouldn't be enough.
I'm curious, the folks that have done a body lift, did you also raise up the fuel tanks?
Seems like it would stick out like a sore thumb if you didn't. I'm guessing it's pretty straightforward and self explanatory, or are there any tips & tricks I should know?
Dieselfumes-aka-Tom
81 Buick Regal Limited, Olds LF9 5.7L (The Neglected Project)
93 Olds Ciera S 3300 daily driver, 285k+
87 Chevy R-10 Silverado 305TBI/700R4 58k, stock 2wd 33x10.5-15 BFG AT, camper shell, Janesville Assembly
Re: Body lift, raise fuel tank?
« Reply #1 on: January 25, 2022, 11:21:15 am »
The fuel tank stays put
Online VileZambonie
« Reply #2 on: February 01, 2022, 04:28:50 pm »
I would rather modify the tunnel than install a body lift. Nothing looks right with a body lift.
Offline JohnnyPopper
  • Old Goof
« Reply #3 on: February 01, 2022, 10:46:29 pm »
I have to agree with VZ.
Suspension lift yes on some trucks, body not so much.
Just doesn't look natural.
But hey! If it floats your boat, play through!  8)
1980 C-10 under construction
Offline wz7u
  • Old, tired - like the truck
« Reply #4 on: February 02, 2022, 01:22:16 am »
I would think raising the tanks up the frame would look weirder. It would be easy enough to fab up some tin to make filler skirts between the frame and body if the light gap underneath was too distracting. Changing the tunnel around makes the most sense to me.
'79 C20 454/th400 "Pearl"
Offline fitz
« Reply #5 on: February 02, 2022, 05:00:46 pm »
Where are you located?
If your in Mass I'll cut a tunnel out of 1 of my 4x4 parts trucks and you can weld it in.
