Author Topic: Ignition switch won’t go to lock position on my 74  (Read 3115 times)
Offline c10rider
« on: February 21, 2022, 06:00:31 pm »
Hello fellas my ignition switch would not go back to the lock position and now it won’t even start, I switched out the ignition cylinder and it still won’t go back to lock , any input would be appreciated I bought this truck with the calum stick converted to floor shift automatic
Re: Ignition switch won’t go to lock position on my 74
« Reply #1 on: February 21, 2022, 06:33:23 pm »
So is it an automatic column or a manual column?
Offline c10rider
« Reply #2 on: February 21, 2022, 07:08:22 pm »
Automatic column
Offline wz7u
  • Old, tired - like the truck
« Reply #3 on: February 22, 2022, 05:36:46 am »
Sounds like the part in the column that follows the shift action has moved from the park position.
On edit - on brother's c10, we cut the rod that went from the quadrant under the hood and welded it to the steering column webbing so it wouldn't move. A usable solution but the steering wheel won't lock any more.
« Last Edit: February 22, 2022, 04:37:34 pm by wz7u »
'79 C20 454/th400 "Pearl"
Offline MIKE S
  • Member
« Reply #4 on: February 22, 2022, 08:15:47 am »
Does the action of turning it to the start position feel normal and engages the starter? If that feels normal can you put the gearshift all the way in park. Does it have a good feel from reverse to park.Can you push the lever up towards park while try to turn key? If you can your linkage is probably out of adjustment. If you still can’t disconnect the linkage at transmission and try again. There is a possibility that the ignition switch rack is broken in the column.
Offline JohnnyPopper
  • Old Goof
« Reply #5 on: February 22, 2022, 04:12:59 pm »
Do you get ignition lights/buzzer?
As Mike said, Look for a problem with the rack. Mine broke some years ago, real pain.
1980 C-10 under construction
Offline blazer74
« Reply #6 on: February 24, 2022, 01:03:35 pm »
Sector gear insider could be broken.
This is a 74 non tilt column with a tooth missing that caused similar problems.
« Last Edit: February 24, 2022, 01:06:46 pm by blazer74 »
