Author Topic: 1/2” Oil Pressure Sender?  (Read 5508 times)
Offline Jon87V20
« on: May 07, 2022, 10:12:28 pm »
The oil pressure sender in my ‘87 Suburban V20 started leaking. I ordered a replacement from Oreilly’s, but it ended up having a different diameter where it threads in. My engine has a fitting between the sender and the block. I think it was probably put there to help the sender clear the O2 sensor.
Anyway, the hole in the block itself is 1/2” too. Oreilly’s says they don’t have that and only have 1/4” or 1/8”.
Do I have some weird size, or is that common? I have a remanufactured 5.7. However, I had transplanted the sender and the fitting from the last engine so that was the same 1/2” as well.
1987 Chevrolet Suburban V20 Silverado
350ci TBI TH400 NP208
Re: 1/2” Oil Pressure Sender?
« Reply #1 on: May 07, 2022, 11:07:56 pm »
The oil galley tap down near the oil filter should be 1/4" NPT.
Offline Jon87V20
« Reply #2 on: May 08, 2022, 09:36:17 am »
Okay. Well that's weird. I wonder how both engines ended up having a ½" tap. I'll go pick up an adapter today I guess. Thanks!
« Reply #3 on: May 08, 2022, 10:57:30 am »
By any chance, are you confusing 1/4" NPT with 1/2" USS?
Offline Jon87V20
« Reply #4 on: May 08, 2022, 12:03:57 pm »
bd, Not sure. I just measured across the diameter of the male side of the sender and it's ½". So is the female side in the block.
Offline Mike81K10
« Reply #5 on: May 08, 2022, 12:33:46 pm »
NPT Thread Size & Pitch: 1/4-18 = Male Thread OD: 13.2 mm / 0.52 Inch = Female Thread ID: 11.2 mm / 0.44 Inch
Need to ask O'Reily if the 1/4 is NPT or Inches!
« Last Edit: May 08, 2022, 12:37:01 pm by Mike81K10 »
« Reply #6 on: May 08, 2022, 12:47:23 pm »
NPT Thread [measures] 13.2 mm [across]
This ^^^^^ should sum it up for you since 1/2" = 12.7 mm.  The two standards (1/4" NPT vs 1/2" USS) measure w/i 0.020" (0.5 mm) of each other.
