Author Topic: Rochester replacement  (Read 3594 times)
Offline JohnnyPopper
  • Old Goof
« on: July 07, 2022, 06:08:43 pm »
Hey gang,
1978 K10 Mr. Goodwrench 350 CID, 350 THD, Converted NP203, 3.41:1, Cali truck, EGR  >:(, Rochester Carb.
I looked for a local rebuild outfit, found two, both said to replace it with an Edelbrock, would get better mileage.
These days I wouldn't mind that!
Any recommendations?
1980 C-10 under construction
  • Old Goof
Re: Rochester replacement
« Reply #1 on: July 07, 2022, 07:30:04 pm »
Should have stated, the reason for the post is I would like to get better mileage.
At these prices it will pay for itself quite quickly.
While you hear Cali State tax is 51-55 cents, when you add it all the other 'fees' it's 1.30 per gallon.
Greetings from the land of Fruits & Nuts!!!  :(
Offline Mike81K10
« Reply #2 on: July 07, 2022, 09:45:08 pm »
I could be wrong! However, I have had both on my truck and did not notice much difference. I have my Rochester back on now. EFI would probably give you better fuel economy.
« Reply #3 on: July 08, 2022, 06:02:34 am »
You won't get better fuel economy from an Edelbrock. If that's the advice they gave you then stay away from them.
Offline Shifty
  • I bleed Bowtie red...
« Reply #4 on: July 08, 2022, 09:07:44 am »
What Vile said...
It's tough to beat a (good running) Rochester with it's smaller primaries for penny pinching mileage.
98 C2500 ext cab longbed
Offline MIKE S
  • Member
« Reply #5 on: July 08, 2022, 03:01:58 pm »
It won't pass smog in Calif with an Edelbrock unless you have friends in low places. ;)
  • Old Goof
« Reply #6 on: July 09, 2022, 04:51:03 pm »
Thanks guys   ;D
I think I'll check out Cliff Ruggles, he seems well spoken of, unless you have a differing opinion.
Offline Stewart G Griffin
« Reply #7 on: July 10, 2022, 10:58:33 am »
Cliff is very good, but he may be backed up.
If so, i have had pretty good luck with this unit:
https://www.jegs.com/i/JEGS/555/15805/10002/-1
i believe these are 83-84 truck cores and i believe they are re manufactured by JET for Jegs.
  • Old Goof
« Reply #8 on: July 10, 2022, 11:17:04 am »
Thank man!
Offline Big Dee
« Reply #9 on: July 10, 2022, 12:47:30 pm »
Used both carbs and the Qjet is on now. it is a bit more effort to tune the rods and jets on the Qjet but it fits right and is the original #'s
The disk brakes should be checked for drag as this will have a large impact on m.p.g..
If the automatic transmission is holding back the truck, it will really slow down the fun factor.
85C30...
