Author Topic: No brakes when engine is running  (Read 33384 times)
Offline CK9404
Re: No brakes when engine is running
« Reply #15 on: August 17, 2022, 10:05:14 am »
No other ideas?
Offline JohnnyPopper
  • Old Goof
« Reply #16 on: August 17, 2022, 02:57:18 pm »
Sorry to leave you hangin...
So with truck in the air, on stands, what ever, will the brakes engage without vac? As in will they stop if you spin the wheels?
With foot on the brake, if you start the engine and engage the transmission, vac off, will it hold the rear tires still?
If they don't stop the rears, turn OFF the motor to let the wheel come to a stop.
Thanks for follow up, it really is weird.
VZ what kind of MC are you talking about? PLS...
1980 C-10 under construction
« Reply #17 on: August 24, 2022, 07:09:18 pm »
I'm super busy, best I can say is I believe I have previously posted on this as well as googling will help you find a bunch of compatible quick takeup masters that will fit your booster. Just pay attention to the line position (typically reversed) and or the need for adapters if keeping the same brake lines.
