Author Topic: Need rear speaker mounts  (Read 14221 times)
Offline Ben_Olddermin
« on: August 14, 2022, 09:07:45 am »
I have some good working 4x10 speakers behind my seat. But there is a problem. They don't fit well in the holes in the corner of the cab. 1987 truck. Single cab.
I have heard that you need some mounting plates. Right now the magnet hits the back. Should I get 6x9" mounting plates? Would 4x10" speakers fit well enough in those?
Thank you.
Offline Mike81K10
Re: Need rear speaker mounts
« Reply #1 on: August 14, 2022, 09:12:15 pm »
You can easily find the "Rear speaker mounting brackets" by doing an internet search. They might be used!
Offline Shifty
  • I bleed Bowtie red...
« Reply #2 on: August 15, 2022, 09:06:57 am »
I have a set that worked/work very well at a very good price.  You'll know who it is as soon as you find his thread.
98 C2500 ext cab longbed
« Reply #3 on: August 16, 2022, 04:58:13 am »
I guess I'm searching wrong. It only comes up with this thread. Found some on amazon, made from aluminum. Should do just fine
« Reply #4 on: August 16, 2022, 07:14:54 am »
are you looking for the stock steel factory mounts for the 4x10?
Offline Shifty
« Reply #5 on: August 16, 2022, 09:09:06 am »
Over at the 67-72 Chevy Truck forum...you know, the light side.... ;)
Offline Geezer77GMC
« Reply #6 on: August 16, 2022, 10:23:24 am »
Offline Shifty
« Reply #7 on: August 16, 2022, 10:42:40 am »
That's them Geez, I wasn't certain of the ethics of the link.   :D
Offline Geezer77GMC
« Reply #8 on: August 16, 2022, 10:54:46 am »
I had my brackets covered in the same materail as the seat & door panels. I added a plywood spacer between the bracket and speaker ring for large magnet clearance. The brackets fit very well and are solid.
« Reply #9 on: August 16, 2022, 07:02:52 pm »
No I already have those. Trouble is they won't fit a modern 4x10. Which I also have.
The 4x10 magnet is too big. So I thought maybe the 6x9 bracket would be better because the hole would be moved. But seeing Geezer's plywood idea makes me want to try that before I order. I could just make some little spacers that would move the 4x10 speaker out so the magnet wouldn't contact the cab. But it's gonna be way out. Maybe 4x10's are just outdated and should go the way of the dinosaur.
Offline Mike81K10
« Reply #10 on: August 16, 2022, 08:37:40 pm »
I have seen them on E.....
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #11 on: November 28, 2022, 12:31:52 am »
I seem to remember something about putting the left speaker bracket on the right and the Right bracket on the left to have more room for the magnet.  IIRC, but you will have to redrill some holes.
Offline JohnnyPopper
  • Old Goof
« Reply #12 on: November 30, 2022, 03:05:19 am »
In any event and with any combo of products please remember to limit these back side speakers to "bass" only.
High freq's are LOST firing into the proximity of our rear end...
If you don't have the electronic ability to steer bass to these speakers, you can snip the lead going to the mid range/tweeter.
The intelligibility will be your reward... 8)
1980 C-10 under construction
