Author Topic: Msd blaster coil on stock 350 tbi  (Read 31246 times)
Offline buzzman351
« on: September 05, 2022, 12:30:35 pm »
Is it worth the money to put the Msd blaster 8226 on my stock truck? Will I still be able to leave my tach hooked up to the coil output lead?
Offline peewee0413
Re: Msd blaster coil on stock 350 tbi
« Reply #1 on: September 05, 2022, 12:32:34 pm »
Not needed even if you could decipher the wiring.
Sent from my SM-S908U using Tapatalk
Offline buzzman351
« Reply #2 on: September 05, 2022, 12:34:28 pm »
So just get the stock coil and keep rolling?
Offline peewee0413
« Reply #3 on: September 05, 2022, 12:38:45 pm »
You don't need any higher voltage or current to make a TBI run. Boost compression,  change fuel, rev higher, etc, and that's a different story when you start talking about ignition. TBI's suck right off the production floor... a blaster isn't gonna give you more power.
Offline buzzman351
« Reply #4 on: September 05, 2022, 12:40:16 pm »
Yeah not trying to get more power just thought a better made part would pay off. I appreciate the help.
Offline peewee0413
« Reply #5 on: September 05, 2022, 12:40:34 pm »
The 350 TBI doesn't even flow enough to support doing anything to a TBI chevy. Takes more than a blaster coil to make a TBI good..
Offline peewee0413
« Reply #6 on: September 05, 2022, 12:46:57 pm »
I read it takes about $2k to get 100hp out of a NA TBI 350.. I put 6k splurged even,  and got a good 350.
https://youtu.be/1_0lmjTg4qo
« Last Edit: January 31, 2023, 09:28:29 am by peewee0413 »
« Reply #7 on: September 05, 2022, 01:07:07 pm »
A good quality stock replacement coil will function perfectly even with moderate performance engine upgrades.  The tach signal universally comes from the negative primary coil terminal with the exception of a few aftermarket CD ignition systems.
