Author Topic: 87 k10 350 tbi tuning?  (Read 47595 times)
Offline JohnnyPopper
  • Old Goof
Re: 87 k10 350 tbi tuning?
« Reply #60 on: April 05, 2023, 02:33:08 pm »
Well Captain, that makes the most sense, since the pump is at the bottom of the tank, and the rubber hose connects the hard line. I hear what sound like circulation, which is probably spraying out of the rubber hose, and accounts for such low pressure.
I found a inline fuel pump from a Benz I had, it measures 50 psi full throttle. Thinking about locating it post fuel filter where hard line converts to rubber.
I'll keep you posted, and THANKS!
1980 C-10 under construction
  • Old Goof
« Reply #61 on: April 21, 2023, 07:46:13 pm »
She Lives!!! ;D ;D ;D
So I placed a pump inline by extending the rubber fuel line, and back then back to the TBI.
It works on both tanks.
Haven't heard her run for months!!!
Offline Shifty
  • I bleed Bowtie red...
« Reply #62 on: April 22, 2023, 10:13:27 am »
Good to hear that she's up and running!  Cheers!  :D
98 C2500 ext cab longbed
  • Old Goof
« Reply #63 on: April 23, 2023, 03:13:37 pm »
Thanks!
Took her up to the car wash for a long overdue scrubbing.
  • Old Goof
« Reply #64 on: May 19, 2023, 08:52:46 pm »
So I took her for some new sneakers on the rear dually's, and she started to choke up, lost power and threw code.
44, so I guess she's running lean? I already changed the 02 sensor.
Looking on ebay/amazon for a OBD1 right now.  >:(
« Reply #65 on: May 20, 2023, 06:49:41 pm »
Why did you use that fuel pump? You need to push the fuel not pull it and you need a steady 13 psi
  • Old Goof
« Reply #66 on: May 21, 2023, 11:09:37 am »
Well I didn't see this pump as a permanent fix. I will get the tank pumps replaced.
It would seem that under load the volume required is impeded by the hose decay between the tank pump and the pick up tube.
  • Old Goof
« Reply #67 on: May 22, 2023, 08:01:13 pm »
Another theory-
Probably had 2-3 gallons, so with the level so low, the secondary pump was most likely drawing air into the damaged hose.
Primary only delivers 5 psi at the moment, so we had a diluted mixture of air and gas.
I bought some 'catcleaner' additive, added 2 gallons, drove for 12 miles, mixed fwy and surface, avg 45-65 mph.
She cleared up nicely after about 5 miles. Filled her up with premium, now let's see if she passes smog... ::)
Oh, and the 32.00 OBD1 doesn't do anything but short 1+2, just like my paper clip!!! >:(
« Reply #68 on: May 23, 2023, 05:40:50 pm »
Right, a code reader is not a scan tool so don't waste your money on one. "Premium" will not help with emissions. In fact it may cause your HC's to increase.
  • Old Goof
« Reply #69 on: May 24, 2023, 10:04:23 am »
So VZ, is there a OBD1 that actually scans? Or do we just have to count the blinky lights?
Offline Mike81K10
« Reply #70 on: May 24, 2023, 02:20:11 pm »
I have an INNOVA Scan Tool 5610 and it does very well on my vehicles made in the 2000s, as for 80s and 90s vehicles there may be additional attachments that can be purchased. It is used with my phone and does a lot. It will break down codes and helps to troubleshoot problems, has many features. You can look it up on line. There are others good ones as well I am sure.
Offline Mr Diesel
  • Aaron
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
  • Old Goof
« Reply #73 on: May 24, 2023, 09:03:34 pm »
Thx guys! Will let you know what happens!
