Author Topic: M21  (Read 7377 times)
Offline Swampyankee74
  • Keep em alive
M21
« on: December 11, 2022, 05:50:18 pm »
This weekend I purchased a muncie m21. My cab has a low tranny hump. The truck originally had a 3 speed manual.  Which is roughly the same size. The truck is all disassembled so it's hard for me to take any measurements. Has anyone put a muncie 4 speed in the low hump trucks? Is there any clearance issues?
Re: M21
« Reply #1 on: December 11, 2022, 07:16:28 pm »
No clearance issues at all.  Same length and will take the same driveshaft yoke as the 3 speed manual
  • Keep em alive
Re: M21
« Reply #2 on: December 11, 2022, 08:20:07 pm »
Thank you zieg! I thought it would work. But no way to measure. Cab is off frame and in a different building. Thank you very much
Re: M21
« Reply #3 on: January 27, 2023, 01:14:22 pm »
You're welcome.  Word of advice.  If you have a high geared truck 2.56,.2.73, 3.08 or 3.42 with oversized tires starting out is not going to be fun.  Typically the M21/M22 transmissions used 3.73 rear or higher which wasn't an issue.  Rowing through 4 gears is fun.
  • Keep em alive
Re: M21
« Reply #4 on: January 27, 2023, 01:26:49 pm »
Yea the rear end is 3.73's. M21 is going behind a stroker that dynoed at 464hp. Tranny was built by a reputable shop outside of boston,, they say good for 800 hp (we'll see), mcleoud clutch, and a lake wood bellhousing. I'm a ways from driving it, but excited. Should be a fun toy.
Sent from my SM-S515DL using Tapatalk
  • Keep em alive
Re: M21
« Reply #5 on: April 13, 2023, 07:23:41 am »
Zieg, what shifter handle did you use on your muncie m? I was told a shifter handle for a chevy 2 nova was what I needed. That it will work with the bench seat?
Re: M21
« Reply #6 on: April 13, 2023, 07:53:37 pm »
Trans was out of a Chevelle
  • Keep em alive
Re: M21
« Reply #7 on: April 13, 2023, 09:21:51 pm »
Thank you zieg
