Author Topic: New guy from SW MO  (Read 23614 times)
Offline Callmebert
New guy from SW MO
« on: February 11, 2023, 11:48:43 am »
Hello all, I just acquired a 1986 SWB C10 that has been sitting for several years. Body is very straight, surprisingly very little rust. I already got it running, but only when pouring gas in the carb. I can’t get anything from the tanks. I believe it is the selector valve for the dual tanks. I will have lots of questions, already impressed with the amount of info on here.
Offline Mike81K10
Re: New guy from SW MO
« Reply #1 on: February 11, 2023, 01:43:49 pm »
Welcome from Alabama! We love pics!
A bad selector valve should be stuck in the left or right tank position if it is bad. So there may be a problem with your fuel system to include the carb.
Check fuel filters, see if there is fuel flow from the pump, check the selector switch and selector valve for power - if they both work you should hear the selector valve when you depress the switch for 2-3 seconds and release, then if problem persist check out the switch and then you can remove the selector valve bench check it and ensure it works and fuel pathways in the valve are clear (they can get clogged up), and inspect the fuel sending units and lines/hoses. Could have kinks in lines and hoses.
The tanks and system can get gummed up and rust is possible, especially if the truck has been sitting for awhile.
Offline JohnnyPopper
  • Old Goof
« Reply #2 on: February 12, 2023, 02:17:28 pm »
Welcome from SoCal!
look forward to progress and pics.
You may know this but pics have to be really low res.
Look for a program called PIXresizer on this site by reference, or elsewhere.
1980 C-10 under construction
« Reply #3 on: February 13, 2023, 09:18:07 am »
Howdy, "Bert!"
Welcome from Central California!
Offline Shifty
  • I bleed Bowtie red...
« Reply #4 on: February 15, 2023, 10:20:43 am »
Welcome from Tucson AZ!  8)
98 C2500 ext cab longbed
Offline dusterdude
« Reply #5 on: February 15, 2023, 04:33:10 pm »
Welcome
Sent from my SM-G973U1 using Tapatalk
« Reply #6 on: April 12, 2023, 04:11:23 pm »
Welcome from the St. Louis area
