Author Topic: 84 Sierra multi function switch removal  (Read 16197 times)
Offline 84GMCSierra
« on: February 18, 2023, 05:42:16 am »
Good Morning everyone. I have an 84 Sierra 2500, with a non tilt, non cruise column, and I need to replace the MF switch(Turn signal, wipers(. but can't pull the old one out to replace it. I believe I should just pull straight out to remove it, but it won't budge, and I don't want to break it. Any suggestions.
Thanks
Re: 84 Sierra multi function switch removal
« Reply #1 on: February 18, 2023, 08:26:44 am »
The column doesn't use a multi-function switch.  Each switch is separate and distinct.  To service the switches, you must remove the horn contacts, steering wheel, dust shield, and lock plate.  The switches then come out through the top of the column.
Offline dusterdude
« Reply #2 on: February 18, 2023, 03:00:13 pm »
If you mean you need to replace the turn signal stalk,then yes it pulls out.watch some youtube videos to get some ideas on techniques to use.
Sent from my SM-G973U1 using Tapatalk
