Author Topic: Dash panel repair?  (Read 9706 times)
Offline Callmebert
Dash panel repair?
« on: March 06, 2023, 11:03:17 am »
Does anyone know of a dash repair panel for the radio area? The previous owner hacked the area up to install a radio. It’s really bad. Looks like they used a hammer and cold chisel. I was thinking of seeing if i could find a junk yard donor, cutting a piece out, then welding it in place.
Offline Callmebert
Re: Dash panel repair?
« Reply #1 on: March 06, 2023, 11:04:16 am »
Btw, it is a ‘86 Scottsdale Swb.
Offline Mr Diesel
  • Aaron
« Reply #2 on: March 06, 2023, 12:21:00 pm »
I think I welded in a patch piece of thin steel on my last one. Of course welding in a cab is full of fire danger since everything in there is combustible. A better solution might be to fashion a metal plate to fit and overlap the edges onto existing material and epoxy in place. Lowes has plenty of plain steel from which to choose.
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
Offline mrghostwalker
« Reply #3 on: March 07, 2023, 03:49:33 pm »
I ended up replacing a section of the dash with a section cut out of a parts-truck. It won't be noticeable if you are careful where you cut it.
« Reply #4 on: March 07, 2023, 04:08:41 pm »
You can always cut out a section from a 89-91 Suburban for more radio choices.
Offline Chevygold
« Reply #5 on: March 09, 2023, 02:14:01 pm »
When I fixed my sun toasted ex Arizona dash panel I just stuck a bit of card on the back then filled over it with glass reinforced filler then after filling all the cracks gave it a light coat of truck bed paint followed by 2K satin black and it looks great!
Graham
