Author Topic: Hood not closing all the way  (Read 23021 times)
Offline Shifty
  • I bleed Bowtie red...
« on: March 06, 2023, 12:42:07 pm »
Mechanically, it will latch, and won't do anything naughty, except look bad from the driver's seat.  (truck is an 87 V20, but the front clip was replaced at some time with an 84 unit)  Fit is good everywhere, hood is not bent, and sits flush at the cowl.   Adjusting the bumpers up or down doesn't change anything.  Is the latch adjustable up and down?  There is about a 1/2" gap above the grill, and I can physically push it down to where it needs to be.
98 C2500 ext cab longbed
Offline Mike81K10
Re: Hood not closing all the way
« Reply #1 on: March 06, 2023, 08:09:26 pm »
You should take pictures of all and attach!
Offline Shifty
« Reply #2 on: March 07, 2023, 08:58:02 am »
I know, I know... ;)
Offline JohnnyPopper
  • Old Goof
« Reply #3 on: March 07, 2023, 06:55:47 pm »
So it's resting on the core support?
Raise the grill?
1980 C-10 under construction
Offline Shifty
« Reply #4 on: March 08, 2023, 08:22:21 am »
Pics will explain it best JohnnyP, but no, it's not even contacting the bumpers unless I push on it.   It's almost as if the springs? aren't pulling it down enough in front, but they do in the back edge.  Sitting in the drivers seat, it looks like I didn't close the hood all the way.
Offline Mike81K10
« Reply #5 on: March 08, 2023, 07:31:39 pm »
Your rear hood mounts might actually need to be adjusted. The back of the rear mount may need to be raised and the front of the rear mount slightly lowered. A small adjustment can make a difference on the front and little difference at the rear of the hood.
  • Old Goof
« Reply #6 on: March 08, 2023, 08:51:23 pm »
if and when you get pics show us the latching mechanism pls.
Offline Shifty
« Reply #7 on: March 09, 2023, 06:38:26 am »
Mike, I think I've heard that somewhere....Johnny, I just went through the older pics I have, and the dang hood looks almost perfect in them...I've got to gt some new ones apparently...
Offline Shifty
« Reply #8 on: March 18, 2023, 12:09:51 pm »
Passengers' side, the way it should look:
Passenger rear:
Drivers' rear:
Drivers side view:
The gap driving me nuts:
Offline Mike81K10
« Reply #9 on: March 18, 2023, 09:05:00 pm »
Is it possible that the hood could be bent/warped.
Offline Shifty
« Reply #10 on: March 18, 2023, 09:53:27 pm »
It could, I guess, it just fits so well everywhere else.  Is there any way to fix this?
Offline Mike81K10
« Reply #11 on: March 18, 2023, 11:01:40 pm »
First find out if it is warped or bent, sometimes it is hard to tell by eyesight. Remove hood and place it on a known level flat surface and see how it looks.
Offline Mr Diesel
  • Aaron
« Reply #12 on: March 19, 2023, 08:22:19 am »
I'm thinking try to adjust the rear mount on that side, as stated above. I bet a small adjustment would clear that up.
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
Offline Shifty
« Reply #13 on: March 19, 2023, 08:41:59 pm »
Thanks for the suggestions all.... 8)
Offline Mike81K10
« Reply #14 on: March 19, 2023, 08:53:46 pm »
Might be able to see if the front lip of hood is straight with a long level or straight stick/metal. Also check radiator support for even adjustment on both sides and measure the amount of fender rise on each side to see if it is the same. Or my earlier suggestion with the back hinge. I had to play with mine quite a bit to get it straight.
