Author Topic: New here , K10 guy  (Read 16263 times)
Offline jwseiberlich
New here , K10 guy
« on: March 06, 2023, 11:50:58 pm »
Hey all,
New here from south jersey .   Check out my ‘85 K10.   Thinking of doing a 4bt Cummins conversion on her with a manual .  Thinking I’ll
Add K20 springs front and rear and her at 14 bolt Semi floater  for the rear-  thoughts on “converting” from K10 to K20?
Re: New here , K10 guy
« Reply #1 on: March 06, 2023, 11:53:01 pm »
« Reply #2 on: March 06, 2023, 11:53:18 pm »
Offline dusterdude
« Reply #3 on: March 07, 2023, 05:28:09 am »
Welcome
Sent from my SM-G973U1 using Tapatalk
Offline Mike81K10
« Reply #4 on: March 07, 2023, 08:22:22 am »
Welcome from AL. You may want to keep what you have and get another K20 or K30 to do the mods, something with a stronger frame. Then again VZ or a few others would be able to give better advice.
« Last Edit: March 07, 2023, 08:23:53 am by Mike81K10 »
Offline Mr Diesel
  • Aaron
« Reply #5 on: March 07, 2023, 08:29:05 am »
It looks good just like that. I would leave it alone and just drive it and enjoy it.
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
Offline Shifty
  • I bleed Bowtie red...
« Reply #6 on: March 07, 2023, 09:01:36 am »
Welcome from Tucson AZ!   (I too would leave it as is)
98 C2500 ext cab longbed
« Reply #7 on: March 07, 2023, 11:01:10 am »
Springs are tired and need to be replaced anyway , same with the beat 305.   Current set up is a 700r4 and a Corp 10 bolt.
So, if I’m changing parts anyway why not upgrade?  As for frame i’ve read before that essentially the 1/2 ton and 3/4 ton are the same, with changes made to driveline/springs/brakes.
Has anyone had both a K10 and a K20 and can confirm this?
Offline JohnnyPopper
  • Old Goof
« Reply #8 on: March 08, 2023, 09:03:38 pm »
Welcome from SoCal the land of fruits and nuts...
What is your aim? Daily, work, what?
Let that determine your changes.
Nice ride, look forward to your progress.  8)
1980 C-10 under construction
« Reply #9 on: March 08, 2023, 09:39:05 pm »
Good question - aim is a solid driver , not daily but often.  Not looking to win races but would love some good torque and fuel efficiency that a diesel offers
And Will use truck as a tow rig (boat or camper).  This rig is also my Home Depot running truck , I’ve been known to source things like heavy pavers/bricks with it.    Here’s a pic of the truck loaded to the wheelwells with bricks from a demolished factory in fishtown, Philadelphia .   Interestingly , but not surprisingly , I dropped a U joint the following day .
Simply, I’d love to beef up the entire truck and make it last a long , long time .
But There won’t be any crazy off roading or abuse of the vehicle, but she gets worked from time to time- it’s a truck, afterall .
