Author Topic: Tooth count of speedometer driven gear in TH350?  (Read 18515 times)
Offline 75ChevDrvr
« on: March 12, 2007, 02:34:00 pm »
Does anyone happen to know or can you find out what the tooth count is for the speedometer driven gear in a TH350.  The truck it came from is a 1975 C10.  Even the tooth count for the drive gear would work.  I just need to figure this out because I can't find my old one.
Thanks!
Offline 75ChevDrvr
Re: Tooth count of speedometer driven gear in TH350?
« Reply #2 on: March 12, 2007, 04:11:00 pm »
True...  It's 3.73 in my truck (stock from the factory).  I don't know what the original tire size was, but it came with 16" wheels.  I do know that I'm running slightly larger tires (265/75-R16) and the speedo always used to be off by a bit.  If I could figure out what the drive gear is, I could get the appropriate driven gear.  If I could figure out what the stock driven gear was, I could figure out what it should be.
chart
« Reply #3 on: March 12, 2007, 04:18:00 pm »
Offline 75ChevDrvr
Re: chart
« Reply #4 on: March 12, 2007, 06:08:00 pm »
I've got about four different sources with the same info on how to calculate the speedometer driven or drive gear now.  What I don't know is the tooth count of either one.  Can anyone help??
Offline DnStClr
Re: chart
« Reply #5 on: March 13, 2007, 12:00:00 pm »
75, have you seen this site? You'll notice that the 3.73 ratio has a bunch of combinations- depending on  your tire size. Measure the tire diameter to get started. Lots of info. Hope it helps. BTW, isn't your drive gear still on the transmission output shaft?
www.transmissioncenter.net/speedometer_calibration_______va.htm
Don St.Clair
Culleoka Tn
Edited by: DnStClr at: 3/13/07 11:26 am
Don
87 Chevy Silverado
Offline 123 pugsy
Re: chart
« Reply #6 on: March 13, 2007, 11:39:00 am »
What color is the drive gear? There is a lot of info about the gear colors and tooth count on the net.
Pugsy
76 C10 LWB
TPI 350
Offline 75ChevDrvr
Re: chart
« Reply #7 on: March 14, 2007, 10:51:00 am »
I hadn't thought about figuring it out by the color of the drive gear!  I forgot those were color coded too.  I kept trying to think about how I was going to count the teeth on it if I couldn't figure something else out.  I'm not sure where my driven gear or the housing went...
Offline 75ChevDrvr
Re: chart
« Reply #8 on: March 14, 2007, 10:54:00 am »
I have seen that PATC site.  I even have a heavily built 700R4 Raptor trans that I put in my truck for a while.  I'm putting the TH350 back in instead so I can sell the truck and hang on to the 700R4 trans to either sell seperately or put in another project.
Offline DnStClr
Re: chart
« Reply #9 on: March 16, 2007, 12:07:00 am »
Know whatcha mean. I bought a TH400 from them and it's sitting on my garage floor still on the pallet after 2 years! I rethought my plans and now want to put in an OD trans like you have.
Don St.Clair
Culleoka Tn
Don
87 Chevy Silverado
Offline 75ChevDrvr
Re: chart
« Reply #10 on: March 16, 2007, 01:55:00 pm »
It's an impressive transmission, that's for sure.  It's somewhere between the top and second to top of their line.  I only ran it for about 3000 miles (about a year).  My truck is mostly a dirtbike hauler, so it doesn't see a ton of miles.  If you're interested, it's basically brand new.  I don't know what I'd have to do to ship it though.  I paid somewhere north of $2k for it, but I'd let it go for $1500.
BTW...  The drive gear in my TH350 is green and I FOUND my driven gear!  It's red!  Thanks for the help though guys!
Offline DnStClr
Re: chart
« Reply #11 on: March 18, 2007, 09:43:00 am »
I already have the 700R4. The Raptor you have is a good one tho! :eek
Don St.Clair
Culleoka Tn
Don
87 Chevy Silverado
