Author Topic: Sticky Brakes caused by old front brake hoses  (Read 23139 times)
Offline fiddler
  • 74 Chevy C10 Stepside
« on: April 05, 2023, 09:38:47 pm »
I have a 1974 chevy C10 stepside.  I couple of years ago I went through the brakes and replaced calipers, wheel cylinders, master cylinder, vacuum booster, vacuum booster hose, proportioning valve, and the y fitting in the rear that distributes from the rear single line to the two rear wheel cylinders.  Brakes were great, then suddenly a couple of months ago the pedal went clear to the top and the rear brakes started coming on before the fronts, (which makes a hard stop a bit of a carnival ride).  Also the brakes would stick on and not release for a few seconds after I took my foot off of the pedal.  Long story short, the front brake hoses had become so narrowed inside that the fluid was slowed going in and going out.  (were they 49 years old??)  Replaced the hoses and good to go again.  Just sharing some experience.....  thanks for all you guys have taught me so far!!
Ricky
Online bd
Re: Sticky Brakes caused by old front brake hoses
« Reply #1 on: April 05, 2023, 10:03:27 pm »
That's a great story.  Thanks for sharing your experience.   8)
Offline Shifty
  • I bleed Bowtie red...
« Reply #2 on: April 06, 2023, 09:51:33 am »
Did you know that brake hoses are the only federally regulated part of a vehicle's braking system?
98 C2500 ext cab longbed
Offline JohnnyPopper
  • Old Goof
« Reply #3 on: April 06, 2023, 12:51:44 pm »
Similar thing happened to me, came to a hard stop and the right brake froze. Pried it back loose, enough to get to a parts store. Thought the caliper had froze, changed out, same. The hose became a one way valve in essence.
1980 C-10 under construction
