Author Topic: Front axle from dually to a SRW truck  (Read 4453 times)
Offline ToreyC
« on: April 06, 2023, 10:38:29 pm »
I’m wanting to see if anybody has ever taken a front axle from a 1 ton dually and installed it on a single rear wheel c10. I have converted my c10 long bed to a 4wd and want to run 1 ton axles. I already bolted up the 14 bolt rear end and I have the 1 ton front end, just need to know if it’ll work. I was told I’d just have to have the hubs machined down to accept a normal rim vs the dually rims. Thanks in advance for any input.
« Last Edit: April 06, 2023, 10:40:29 pm by ToreyC »
81 LWB 2WD converting to 4WD Chevy
85 SWB 2WD Chevy
2011 Chevy Suburban 4WD
2003 Chevy Express Van (Work Truck)
Without The Risk There Is No Reward
Offline ehjorten
Re: Front axle from dually to a SRW truck
« Reply #1 on: April 07, 2023, 09:13:47 am »
Apparently you can machine down the dually adapters, but usually you just buy SRW hubs. The only difference in the axle is at the hub. Dually's usually do have a larger outer bearing and have a higher weight rating because of it. However, the D60 difference is just the hubs.
-Erik-
Offline ToreyC
« Reply #2 on: April 07, 2023, 02:12:53 pm »
Great to know. I appreciate that information!
85 SWB 2WD Chevy
