Author Topic: Brake lights stay on  (Read 7923 times)
Offline bigblockchevelleman
« on: April 20, 2023, 08:06:18 pm »
1987 chevy truck  brake lights stay on have replaced the switch no help even with the switch unplugged brake light will come on when I install the bulb  any help or suggestions would be great THANKS Steve
Re: Brake lights stay on
« Reply #1 on: April 20, 2023, 08:17:55 pm »
Make sure the emergency flasher switch isn't depressed.  What happens if you unplug the turn signal switch?
« Reply #2 on: April 21, 2023, 09:25:55 am »
Haven't tried unplugging anything  , turn singles work  , flashers stay solid  ( thinking it should because only have front bulbs in ) going to start tracing from the tail light forward because I had the bed off while painting ,everything was apart because because it's a complete rebuild  and I know it's something I missed or have caused like so many other small issues I've corrected  Thank for the help Steve
Offline Mike81K10
« Reply #3 on: April 21, 2023, 09:54:34 am »
Was your lights working prior the removing the bed? If yes and the only thing you have done was disconnect the rear harness, that may be where your problem is.
« Reply #4 on: April 21, 2023, 10:47:31 am »
First, this ^^^^^.
Second, only after the first step is verified and the problem persists, unplug the turn signal switch alongside the steering column.  If the brake light remains illuminated, the brake/turn circuit is shorted to B+ somewhere in the wiring between the turn signal switch and the rear lamps.  Otherwise, the issue lies in the brake lamp feed between the brake lamp switch and the turn signal switch, inclusive.
« Reply #5 on: April 21, 2023, 09:26:28 pm »
Thanks  ,today I unplugged the wires from the lights and tested the plug and it's hot somewhere forward the plug that I unplugged was where I unplugged when I took the bed off . Is it possible if the brake light fuse is blown to cause a backfeed  ? Thought of that after I had come to the house  , I did replace the multi function switch hoping it would correct the wiper delay unfortunately it didn't fix delay thank you for your help and time Steve
