Author Topic: Air conditioner compressor belt.  (Read 2886 times)
Offline fiddler
  • 74 Chevy C10 Stepside
« on: April 24, 2023, 07:28:01 pm »
I have a 1974 chevy c10 stepside.  350 engine with air.  The air conditioner belt is somewhere around 58 inches.  Does anybody have a part number for that particular belt?  It goes around one of the harmonic balancer pulleys, and the power steering, and the water pump and the air conditioner compressor.  I am buying a belt at a time to get the right one but if someone has a part number it would make my process faster...  Thanks for any help....
Ricky
Offline Rapid Roy
  • Euless, Texas
Re: Air conditioner compressor belt.
« Reply #1 on: April 24, 2023, 09:05:28 pm »
If it is a stock setup, you can get one at any auto parts store. Search for it online.
Mopar by Birth
Chevy by Choice
Offline Mike81K10
« Reply #2 on: April 24, 2023, 09:34:41 pm »
You can look at belts by length at the local part stores. That is what I did. If your used belt has a part number look it up, if not measure it and then look at belts by length. I attached a pick of my a/c belt with a Gen Air system. It was 59 5/8". I bought it because of the length.
If you go the Gates Web site you can look up the belt by length.
https://www.gates.com/us/en/search.html?searchType=product&text=58%22+V+belt
Other manufacturer's may do the same thing. I just looked at Gates products.
Offline Shifty
  • I bleed Bowtie red...
« Reply #3 on: April 25, 2023, 10:46:50 am »
Gates says the factory outside measurement is 55.29, Dayco says 55.07, but if you want a custom size, you could order a 15580 in Dayco, or 7580 in Gates.
98 C2500 ext cab longbed
Offline fiddler
« Reply #4 on: April 25, 2023, 02:44:11 pm »
I don't know why this setup is not some standard part.  Truck has been through many hands over the years.  I have a few belts on order from amazon.  I will just return the unused ones.  I should be able to narrow it down by installing just a couple.  Measuring says 58 inches but 58 was too big.  I have half inch graduations on order down to 56 inches....
Ricky
Offline Shifty
« Reply #5 on: April 25, 2023, 02:52:59 pm »
Does your truck have headers?
« Reply #6 on: April 25, 2023, 06:06:24 pm »
7545
Offline fiddler
« Reply #7 on: May 03, 2023, 06:56:38 pm »
No headers thank you.  I ordered a series from Amazon and returned the ones that were too long or too short.  Turns out I need the 7570 which is just over 57 inches for my configuration, which is probably some mix of years.  Thanks all for your help.
Ricky
