Author Topic: 1984 K10 electrical Woes  (Read 6038 times)
Offline ackland3
  • Shade Tree Certified Mechanic
« on: June 23, 2023, 09:15:21 pm »
So i got my new K10 and on the way home stopped for gas and it wouldn't start no click on solenoid nothing at all and ended up getting towed home. Went ahead and replaced starter cleaned up some wiring etc. and no crank no start again! after hours of trying to find what was wrong I jumped the starter using a screwdriver and it turned just fine, crawled in and tried the key again for giggles and wouldn't you know it it started right up! any ideas on what it could be?
1985 K10
305
Re: 1984 K10 electrical Woes
« Reply #1 on: June 23, 2023, 10:43:17 pm »
1)  Check the ignition switch adjustment and function
2a)  Auto trans - check the neutral safety switch operation
2b)  Std trans - check the clutch start interlock switch operation
