Author Topic: Rally Wheels Hub Caps  (Read 16857 times)
Offline hdaniels
« on: July 14, 2023, 04:27:09 pm »
Thought maybe someone here would know the answer. Some Rally wheel hub caps have a square indent in them. Was there some square washer / spacer that filled in that area from the factory? I don't see any spacers or washer available for that space.
1973 K5 Blazer 4x4
Offline Shifty
  • I bleed Bowtie red...
Re: Rally Wheels Hub Caps
« Reply #1 on: July 15, 2023, 11:00:52 am »
I *think* the recess is more designed for the plastic lug nut covers to have room.  I could be completely wrong though, as my wife reminds me often.
98 C2500 ext cab longbed
Offline JohnnyPopper
  • Old Goof
« Reply #2 on: July 17, 2023, 07:28:39 pm »
It may have been part of a jig used in production, there are no other square areas.
I have done the exact refinishing of my hubs.
Are you going to paint the bolts that hide the squares?
1980 C-10 under construction
Offline Shifty
« Reply #3 on: July 18, 2023, 09:22:58 am »
I misread the question....nevermind my response.
Offline hdaniels
« Reply #4 on: July 18, 2023, 11:38:30 am »
Did not paint the bolts, went with some polished stainless steel allen button head bolts.
1973 K5 Blazer 4x4
Offline Shifty
« Reply #5 on: July 18, 2023, 12:49:08 pm »
Looks very nice!  :D
  • Old Goof
« Reply #6 on: July 18, 2023, 02:22:27 pm »
Looks nice!
Those self tappers from the factory can strip out.
One of my wheels had like two that were.
Good thing there are drilled holes between lugs that I could drill and tap. Good as new!
Did you clear coat the wheels? I used wheel paint the first time and did not CC. Second time I did, what a difference!
