Author Topic: Air blows sometimes, most times it doesn't  (Read 39815 times)
Offline juancano
« on: September 07, 2023, 08:48:58 pm »
Hi; 1986 Silverado. This truck had AC but at some point it was removed.
If I try to use the Vent to blow air, nothing happens 75% of the time. Then sometimes after it's been "on" for a bit, it starts up and I get air blowing.
I can't seem to find a pattern. I don't understand enough of how it works.
Any ideas? Thank you.
Offline Mike81K10
Re: Air blows sometimes, most times it doesn't
« Reply #1 on: September 07, 2023, 09:11:25 pm »
I had a nest in my unit by the doors that prevented the doors from operating properly. I believe others have experienced the same. Pull the unit off and check inside would be one suggestion.
Your fan could also be going bad or you might have a bad wire connection. Check connector to fan, clean if needed.
« Last Edit: September 07, 2023, 09:13:15 pm by Mike81K10 »
Offline juancano
« Reply #2 on: September 08, 2023, 08:20:35 am »
I'll do that; where is the fan in this truck? Under the dash or under the hood? Wondering if it's part of the old AC leftover parts. Thanks
Offline Mike81K10
« Reply #3 on: September 08, 2023, 01:33:41 pm »
Firewall Passenger side, under the hood.
Offline juancano
« Reply #4 on: January 24, 2025, 01:59:32 pm »
I cleaned the old blower fan a while back, and this week I put a brand new AC blower from a 1994 Truck. Same result.
I am thinking next steps is checking the heater box and see if the flaps open correctly. My heat also doesn't seem to work. Heater core replacement then.
« Reply #5 on: January 24, 2025, 02:20:43 pm »
Does the blower motor turn on like it should but no air flows from the vents, or is the blower motor dead?
