Author Topic: What is this: Under wheel-well plate  (Read 9018 times)
Offline IdahoMan
« on: September 18, 2023, 02:49:45 pm »
Hi,
What is this bolted-on plate under the front/right wheel-well? I want to take it off and inspect/repair the rust (You can see there is a rust-hole underneath).
Can it be taken off and put back on easily?
How can that hole be repaired via body shop?
Thank you,
IM
« Last Edit: September 18, 2023, 08:13:09 pm by IdahoMan »
Offline JohnnyPopper
  • Old Goof
Re: What is this: Under wheel-well plate
« Reply #1 on: September 18, 2023, 03:30:24 pm »
Do we have to travel to Idaho to see it?  :D LOL
Post a pic please... ;)
1980 C-10 under construction
  • Old Goof
« Reply #2 on: September 19, 2023, 05:46:14 am »
Looks like the support brace these girls came with to knock down the incessant rattle that was otherwise present...especially wind related.
Offline Mike81K10
« Reply #3 on: September 19, 2023, 07:52:31 pm »
Take the wheel well out and re-install after you repair.
Offline Chevygold
« Reply #4 on: October 30, 2023, 03:30:47 pm »
I found mine was spot welded to the wheel well so it's a kind of reinforcement plate.
Graham
Offline Shifty
  • I bleed Bowtie red...
« Reply #5 on: October 30, 2023, 04:22:25 pm »
Does it correspond to where the jack mounts?
98 C2500 ext cab longbed
  • Old Goof
« Reply #6 on: October 30, 2023, 08:00:14 pm »
Inner fenders are easy to replace and are not that expensive.
Gives you an excuse to clean up the inside of the engine area provided you paint them or they come in the finish you want  ;D
« Reply #7 on: October 31, 2023, 08:03:01 am »
That panel is part of the inner fender.
