Author Topic: Sm465 won't go into reverse  (Read 9263 times)
Offline burnze
« on: October 16, 2023, 07:26:42 pm »
I'm working on a 88 blazer with a sm465 my daughter borrowed this truck when I got it back the clutch pedal went to the floor. Replaced the slave cylinder then started it won't go into reverse. I pulled the shifter and found out why my question is what would cause this? The tunnel is welded so I can't get the top cover off with out cutting the tunnel ...dont really want to do this if the tranny has to come anyway I have a top cover off of a 78 465 will that work
« Last Edit: October 16, 2023, 08:03:43 pm by burnze »
83 gmc crew cab
84 chevy blazer
87 r10 short box
Offline JohnnyPopper
  • Old Goof
Re: Sm465 won't go into reverse
« Reply #1 on: October 17, 2023, 06:52:48 pm »
Trying to figure out what we're looking at.   ???
Is the 'tunnel' you refer to the hump in the floor?
1980 C-10 under construction
Offline burnze
« Reply #2 on: October 18, 2023, 02:30:16 pm »
The picture is the top cover looking down the shifter hole I'm guessing the clip failed on the reverse plunger. It looks like there is wear where the plunger should be not sure what would cause that. Yes I was referring to the hump
83 gmc crew cab
84 chevy blazer
87 r10 short box
  • Old Goof
« Reply #3 on: October 23, 2023, 10:20:24 pm »
Thanks for clearing that up.
I thought my kids were the only ones that return stuff broke... :(
I thought the humps were removable, as in making room for transmission variations.
Offline ehjorten
-Erik-
  • Old Goof
« Reply #5 on: October 24, 2023, 11:01:35 pm »
Good to know for Mr. Burnze!
Somehow I think he's going to have to pull it out to clean the remnants of debris, otherwise known as 'hamburger helper'...
