Author Topic: Fastener material (steel, stainless, zinc, chrome, etc.)?  (Read 6253 times)
Offline IdahoMan
« on: October 28, 2023, 02:03:19 pm »
I'm putting my truck back together (lights, mirrors, grill and drip-rails) and am trying to get the right fasteners.
Looking at the fasteners I removed, some like the DR ones look to be the black kind and a bit rusty, some like the roof light are shiny an non-magnetic (I assume SS). The wheel-well trim screws that are always a bear to remove are magnetic and shiny and look OEM (nickle-plated?).
So I ask: What's the ideal fastener material, and more importantly what reaction will it have to metal it is being screwed into? (Ex: on body sheet metal, I'd much rather the fastener rust than the body)
Secondly: What could/should I dip the fasteners in when re-screwing to help seal out moisture (this is especially important on the DRs), a silicone or Right Stuff?
Thank you!
Re: Fastener material (steel, stainless, zinc, chrome, etc.)?
« Reply #1 on: October 31, 2023, 11:18:07 am »
Generally the Drip rails have a gasket on the back sealing the surface from water penetration.  It would be a black glue strip on the back. These are typically black metal screws.  If you want to put a dab of silicone on them I would put it under the screw head.
The roof lights and from what I remember the wheel trim were stainless but I haven't mess with any in a while.
As far as metal reactions you can probably google this but are you looking for something specific from the community?
Offline Mr Diesel
  • Aaron
« Reply #2 on: October 31, 2023, 01:05:36 pm »
Use stainless. I suppose someone somewhere might want to debate metal reactions, but the fact remains that you will have less rust problems by using stainless. I use a dab of grease on threads to prolong the antirust effect, but rust is always looking for a way to creep in. Keeping them dry is single biggest factor, so using that gasket between rail and body is important.
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
