Author Topic: Running lights - Base/Gaskets?  (Read 8852 times)
Offline IdahoMan
« on: October 29, 2023, 04:01:49 am »
My roof lights, the rubber is getting kind of dry. What's a source of good, non-chinese base/gaskets? It's a 1981 Silverado. (I've got some brand new lenses that are made in US if you can believe it)
Also, is there a safe type of sealant that can go on between the paint (or in my case, RaptorLiner) and the gasket for good measure? Some kind of silicone or something that can be removed later without harming the body or the rubber?
Thank you,
IM
Offline Mr Diesel
  • Aaron
Re: Running lights - Base/Gaskets?
« Reply #1 on: October 29, 2023, 09:17:27 am »
Not sure about gaskets, but for sealer I would go to a Lowes or hardware store and get some caulk in a tube. I recommend black color that will clean up with water before it dries (not silicone). I used some stuff like that for weatherstripping on a Camaro and was pretty happy with it. Water cleanup made it easy to wipe excess off the paint with a damp towel.
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
« Reply #2 on: October 31, 2023, 08:35:30 am »
Check with https://www.truck-lite.com,
These are the actual lamps used from 1969-up:https://www.truck-lite.com/1313a.html
There is a whole thread on these somewhere on the forum.
Offline Mike81K10
« Reply #3 on: October 31, 2023, 04:15:33 pm »
What about making your own gaskets out of a thin rubber gasket material!
Offline IdahoMan
« Reply #4 on: November 10, 2023, 11:42:54 am »
I may just have to!
Or maybe put Vaseline on the joining parts and press RTV Right Stuff gasket-marker in-between them and form a gasket?
