Author Topic: Trying to identify what axles I have in 77 K20  (Read 26269 times)
Offline 77 K 20
« on: November 12, 2023, 03:41:59 pm »
Hello to all I have a 77 K 20 that I'm just starting to work on. I'm trying to figure out the rear end which is a 14 bolt with a stamping # RJHG 1112 and a front axle of 6302C4 which is a DANA I think. Took the rear drums off to check the linings and found more parts on one side than the other for bearing adjustment.  On the left it had an extra tanged washer between the first bearing and nut. Can't find any info if it's supposed to be there or not. Haven't been into one of these rear ends in a long time. Any help or diagrams would be helpful and appreciated. Also does anyone know how to go about getting a build sheet on my truck. It seems as though the mice wanted it more than they thought I needed it. Just some small scraps were left with RPO codes but nothing about axles. Thank you in advance.
Offline Mr Diesel
  • Aaron
Re: Trying to identify what axles I have in 77 K20
« Reply #1 on: November 13, 2023, 05:33:48 pm »
I think it should be a Dana 44. Can't help with the build sheet.
Both sides should have that tanged washer. It locks into the plastic in the nut to keep from backing out and getting loose. I'm doubt it would cause any problems without it though.
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
Offline 77 K 20
« Reply #2 on: November 16, 2023, 07:30:03 pm »
Mr Diesel Thanks for the insight. Further searching I find a 44 stamping next to the cover on the front.
