Author Topic: Gauge fuse current rating?  (Read 8231 times)
Offline Scaryfastatx
« on: December 02, 2023, 10:12:47 pm »
Hey everybody, curious what current rating is the factory fuse on the gauges circuit?
My original fuse block had a 20A fuse on there
But my American Autowire Classic Update schematic and instructions say it needs to be 5A
But it's randomly popping. I checked the cluster and everything seems fine
Thanks
Offline JohnnyPopper
  • Old Goof
Re: Gauge fuse current rating?
« Reply #1 on: December 03, 2023, 06:18:13 pm »
Try an amp test and go with a fuse that's 20% higher.
1980 C-10 under construction
« Reply #2 on: December 03, 2023, 11:26:57 pm »
Per the 1981 C10 factory wiring manual, the "GAUGES" fuse is 20 amps.
  • Old Goof
« Reply #3 on: December 05, 2023, 09:33:07 pm »
What size fuse are you using?
« Reply #4 on: December 08, 2023, 08:55:08 pm »
5A it's been fine the last week or so. I think maybe hot swapping the fuse for the courtesy light caused it to pop maybe
« Reply #5 on: December 08, 2023, 08:56:08 pm »
Ok awesome thank you.
I'm curious what American Autowire went to a 5A for that circuit
