Author Topic: 1987 v10 dome light, horn not working  (Read 7079 times)
Offline 1987copper..v10
« on: January 11, 2024, 06:26:55 pm »
1987 v10 dome light, horn not working. I've got hot going to dome and checks out fine, ran continuity with multimeter on ground, and get a decent reading, assuming i'm reading multimeter correctly. I thought ground(orange/white running to dome) may be corroded running through door threshold, so I cut it by fuse box, pushed on horn...and nothing, so i assume that ground is fine....Checked ground cluster behind instrument panel, detatched , inspected connections, everything looks fine, no corrosion.... checked door/dome light switch on driver side, looks perfect
Re: 1987 v10 dome light, horn not working
« Reply #1 on: January 11, 2024, 06:46:46 pm »
Are you sure the dome lamp bulb is good?  Orange is B+, white is switched ground.  Reconnect the wires that you cut.  Probe the orange wire using a test light clipped to ground to verify battery voltage.  Then jump the white wire directly to a shiny clean bare metal ground.  Does the dome lamp illuminate?
« Reply #2 on: January 12, 2024, 02:41:07 pm »
I had this same exact problem about 15 years ago on my 85.  I think it was a fuse, caused by a bad ground.  Check your fuses.  Clean the ground on the left rear tail light.  It didn't make sense that it was all connected.
« Reply #3 on: February 05, 2024, 03:09:04 pm »
Bulb is good...orange is good, fuse is good, I think the ground is ony half good, or half bad, haven't worked on it yet... thanks for the replies, I'll update once I get a chance to work on it.
