Author Topic: 357 (350 - .40 Over) Build Questions Etc  (Read 114935 times)
Offline Mike81K10
Re: 357 (350 - .40 Over) Build Questions Etc
« Reply #75 on: May 04, 2024, 05:37:30 pm »
My pushrods measurements came up .600 shorter than the OEM I had in my crate engine. Don't know if it is partly because of 1.6 scorpion roller rockers, the heads, or the roller engine block. Everything is different then the old flat tappet GM Block. My old pushrods were 7.800.
« Reply #76 on: May 04, 2024, 05:57:51 pm »
It's because you need the roller cam pushrods. Like a 1995 caprice 5.7L engine etc
Offline Mike81K10
« Reply #77 on: May 04, 2024, 08:43:36 pm »
I have seen a few different methods for measuring push rod lengths. I will do my measurements again tomorrow to double check my pushrod length and the proper geometry of my rockers arms/lifters.
« Reply #78 on: May 05, 2024, 07:30:10 am »
Don't over think it. You need the pushrods I mentioned above.
Offline Mike81K10
« Reply #79 on: May 05, 2024, 11:58:55 am »
I checked out the 1995 Cprice  5.7L engine and the pushrods run just over 7.8 in length. I used a couple of methods now (last time today) to check for the correct pushrod lengths and both methods came up to a 7.200 pushrod length.
The last method I used to check the pushrod length was very easy and effective. I checked for the rocker geometry, which gives you the length of the pushrod. Seemed to be very accurate.
Rocker Geometry:
1) The Gross Valve Lift of Cam: .792 / 2 = .396
2) Thread Pitch on 3/8” studs = 24 TPI (.042” per turn)
3) Make 90 Degree Mark on rocker arm (Center bearing to Center roller)
4) Put a mark on top of adjuster nut so the number of turns can be counted
5) Put Rocker on the stud and measure with an Allen wrench from valve to stud the 90 degree line.
6) Figure to determine turns on adjuster nut: .396 /.042 = 9.43 (turns needed)
7) Put tape on top of adjuster nut and mark it to determine the number of turns.
Figures:
Intake Lift .495
Exhaust Lift .502
Rockers 1.6:1 (Full Roller - Scorpion Rockers)
.495 x 1.6 = .792 (Gross Lift)
.792 / 2 = .396 (Half of gross valve lift)
.396 / .042 = 9.43 (Turns needed on adjuster nut)
Afterwards: Insert and adjust pushrod checker, then removed rocker and pushrod checker. Measure pushrod checker.
Equation used to find Gross Valve Lift:
Intake Lobe Lift x Rocker Arm Ratio = Inches Gross Lift
I went ahead and ordered and the information on the pushrods from Summit Racing is below:
HDR Thickwall Chromoly Pushrods SUM-14957200
Compatible with Guideplates: Yes
Pushrod Tube Diameter: 5/16 in.
Pushrod Material: Chromoly
Top Tip Style: Ball
Bottom Tip Style: Ball
Intake Overall Length (in.): 7.200 in.
Exhaust Overall Length (in.): 7.200 in.
One-Piece Pushrod: Yes
Oiling: Yes
Tapered: No
Tip Attachment: Formed
Top Tip Diameter: 5/16 in.
Bottom Tip Diameter: 5/16 in.
Wall Thickness (in.): 0.105 in.
Heat-Treated: Yes
Quantity: Sold as a set of 16.
Notes: Commonly used with SBC O.E. hydraulic roller cams, .105 wall 210 degree ball ends.
Summit Racing™ HDR Thickwall Chromoly Pushrods
Summit Racing™ HDR premium thick-wall pushrods are a great upgrade for your engine. Factory pushrods (and even .080 wall aftermarket versions) act like a pogo stick in a running engine. Not only is static spring pressure working against them, it's also the valvetrain inertial mass increasing with RPM. This reduces power and valvetrain life. While a .080 thin-wall pushrod may not break, it doesn't mean it's the best option.
Enter the HDR's. Summit™ used FEA (Finite Element Analysis) in the initial testing. We didn't just compare them to thin-wall welded-ball factory pushrods, but with aftermarket models, as well. The results speak for themselves!
* The Summit™ HDR 5/16 x .105 wall pushrods have 20 percent less stress and 25 percent less deflection than a typical 5/16 x .080 chromoly pushrod
* The Summit™ HDR Pro LS 11/32 x .120 wall have 25 percent less stress and 28 percent less deflection than a typical 5/16 x .080 wall chromoly pushrod
« Last Edit: May 05, 2024, 12:03:14 pm by Mike81K10 »
« Reply #80 on: May 06, 2024, 04:03:43 pm »
Quote
That's not correct: MPR373
Overall Length (in): 7.195 Inch
Overall Length (mm): 183mm
Shaft Diameter (in): 5/16 Inch
Shaft Diameter (mm): 7.92mm
Top Tip Type: Ball
Bottom Tip Type: Ball
Top Tip Diameter (in): 0.312 Inch
Top Tip Diameter (mm): 8mm
Bottom Tip Diameter (in): 0.312 Inch
Bottom Tip Diameter (mm): 8mm
Wall Thickness (in): 0.060 Inch
Wall Thickness (mm): 1.524mm
Oversize (in): 0 Inch
Oversize (mm): 0mm
Material: Steel
Drilled: Yes
Offline Mike81K10
« Reply #81 on: May 06, 2024, 04:12:40 pm »
Guess I must have looked at the wrong ones. Thanks!
AFR and Scorpion informed me that I have to use after market hardened 5/16", chromemolly, heat treated, thick walled push rods for my engine.
« Last Edit: May 06, 2024, 04:20:21 pm by Mike81K10 »
« Reply #82 on: May 06, 2024, 05:49:13 pm »
Yes because you have guide plates.
Offline Mike81K10
« Reply #83 on: May 06, 2024, 08:00:54 pm »
Thanks for clarifying why!
I have never used aluminum heads before nor guide plates. My prior engines were Gen I flat tappet cam engines with iron heads. I am learning some new things with this engine build that I did not know prior. My prior build was easier to deal with and this one is becoming much more expensive.
Offline Mike81K10
« Reply #84 on: May 08, 2024, 09:57:11 am »
Got my pushrods in last night and installed them this morning. Will soon put my engine in my truck! I could not find 5/16" push rods with a .125" wall, those I got are .105" wall. So they are thicker than normal for guide plates. Larger diameter rods have thicker wall options.
I have been keeping areas that access is not needed closed off to prevent dirt and anything falling in. Including the valley with valves and rods, covering removed for pic.
Offline Shifty
  • I bleed Bowtie red...
« Reply #85 on: May 09, 2024, 09:48:54 am »
Almost too pretty to cover up, eh?  8)
98 C2500 ext cab longbed
Offline Mike81K10
« Reply #86 on: May 09, 2024, 06:30:15 pm »
Did not have much time to get a lot done today. However, I installed my intake and used Loctite 518 Anaerobic Gasket Maker 2096059 with the spray activator on the four corners were the gaskets meet. Usually use Permatex Silicone gasket maker and sealer on that. My valve cover gaskets is a little thick and will need to get some mounting hardware for them, cannot use the OEM I have.
Offline Mike81K10
« Reply #87 on: May 11, 2024, 03:54:38 pm »
What is the opinion on the forum about lifting the engine with the cherry picker by the accessary bolt holes on the sides of the heads (aluminum heads)? Is it really safe or is there a better way of lifting the engine? I am used to cast iron heads and would not even second guess lifting them by the accessary bolt holes. However, aluminum is a different story. I have heard of people lifting with the carb plate on aluminum intakes and I think that is crazy. A straight lift on threads sounds worse that those on the side of the engine. I will soon install my new engine in my truck and am curious if I will be OK using the front and back of the aluminum heads.
« Reply #88 on: May 11, 2024, 05:53:38 pm »
Yes you'll be fine
Offline Mike81K10
« Reply #89 on: May 11, 2024, 06:18:34 pm »
Thanks VZ! Having Aluminum heads and such is new to me and it makes me nervous with how much they cost.
I remember when I was about 19 Years old and was working on a Chevy Vega I had bought used. I stripped some bolts while tightening some parts on the engine. I actually had forgotten about that car. My third vehicle I had purchased. I was going to put a 350 engine in it, then decided to just sell it. Body on it was perfect! The engine smoked a little bit but ran.
I removed the exhaust system from my truck today and will begin searching for a stainless steel system to install. I would like to know if anyone knows of a trans cross member for dual exhaust for a 1981 K10 that would work, or if I should even bother with one.
« Last Edit: May 11, 2024, 06:23:20 pm by Mike81K10 »
