Author Topic: Power Steering Squeal  (Read 17024 times)
Offline Langley89
« on: March 22, 2024, 12:01:11 am »
So I finally got my 1985 K20 6.2L up and running and noticed when I turn the wheel to far the power steering pump seems to try and stop. Same thing seems to happen when you press the brakes all the way in while parked. I’m leaning towards it needs a new power steering pump.[img]
1985 Chevy K20 6.2L
Offline Shifty
  • I bleed Bowtie red...
Re: Power Steering Squeal
« Reply #1 on: March 22, 2024, 10:04:23 am »
Possible air in line?
98 C2500 ext cab longbed
« Reply #2 on: March 22, 2024, 10:19:27 am »
Have you checked belt condition and whether the belt is taut?
Offline Langley89
« Reply #3 on: March 22, 2024, 06:05:03 pm »
How would I check for air?
And the belts don’t look bad but I have another set coming just in case
1985 Chevy K20 6.2L
« Reply #4 on: March 22, 2024, 07:31:05 pm »
But are the belts sufficiently tight?
Air in the P/S fluid generally results in a "whine" rather than "squeal."  Remove the P/S cap to ensure the proper fluid level and inspect for foaming of the fluid.  There should be no air bubbles in the reservoir.  Reinstall the cap and run the engine, cranking the steering wheel and pouncing on the brake pedal to recreate the noise.  Shut the engine off then recheck the P/S fluid for air bubbles or foaming.
