Rear Drivelines, Drive Axles and Gearing
Something is scrapping the driveshaft!
Topic: Something is scrapping the driveshaft! (Read 26804 times)
philo_beddoe
77 C-10
April 18, 2024, 04:08:42 pm »
Well, I know what is hitting it, had lots of bags of soil, mulch, that sort of thing in the bed, on way home from wmart, when hitting a drop in the road, or bump, I could hear the scrape. Why is this hitting, can I cut a space in this stupid rivited on box? And why is it rivited, and not simple bolts?
Swampyankee74
Keep em alive
Re: Something is scrapping the driveshaft!
April 18, 2024, 06:36:27 pm »
Looks like a bracket for a bearing on a two piece driveshaft. If so grind the rivets off and pull the bracket
Scott91370
April 19, 2024, 11:05:20 am »
I agree, it does look like it would be a carrier bearing mount. If you're never going back to a 2 piece drive shaft, just cut the entire mount out.
philo_beddoe
77 C-10
April 23, 2024, 08:44:48 pm »
Yup, so far that’s the plan. Thanks
philo_beddoe
77 C-10
April 28, 2024, 10:24:08 pm »
Well I unriveted that useless box, gone! Cleaned the area and painted. Looks like it was never there. Will add pic when I get a chance.
Shifty
I bleed Bowtie red...
April 29, 2024, 09:29:54 am »
Aww man! Why did you remove your roadkill-scraper-mount?
98 C2500 ext cab longbed
philo_beddoe
77 C-10
May 21, 2024, 06:26:12 pm »
philo_beddoe
77 C-10
May 21, 2024, 06:42:13 pm »
Carrier bearing support bracket gonzo….
Shifty
May 23, 2024, 09:48:08 am »
Look at you, lowering that drag coeffecient! OK, still a brick....
philo_beddoe
77 C-10
May 23, 2024, 10:33:53 pm »
Quote from: Shifty on May 23, 2024, 09:48:08 am
