Author Topic: Needing GM Steering Pump model for recent conversion from manual steerin  (Read 25395 times)
Offline Mickey Swaggerty
I recently converted my 77 6 cylinder 77 C10 over to power steering. The pump I have isn't working while at a dead stop, or turning while driving below 10 mph. I am sure it is the pump. Can anyone recommend a Saginaw style pump model that will work at very low speed. It has to be a Saginaw style pump in order to work with the specific pump brackets that fits on an inline 6. All suggestions are appreciated.
« Last Edit: December 24, 2024, 03:58:26 pm by Mickey Swaggerty »
Offline JohnnyPopper
  • Old Goof
Re: Needing GM Steering Pump model for recent conversion from manual steerin
« Reply #1 on: December 24, 2024, 05:45:54 pm »
A Saginaw pump in good shape should work all the time regardless of speed. Change it out with the same and it should take care of the problem.
One question: do you have the correct size pulleys? Not that I have seen a significant difference through the years. If the crankshaft pulley is too small it could be the problem too.
1980 C-10 under construction
