Author Topic: 1987 R20 w/454 TBI motor not starting after heavy rain  (Read 29014 times)
Offline JensenHealey
« on: April 12, 2025, 01:29:38 pm »
I have been struggling with a no-start issue on my 1987 R20 with 454TBI motor after a heavy rain storm. I have tried replacing the ignition wires multiple times with no change in behavior. The weather has to pretty warm for a day or two after a rain storm for the truck to start again. Today is two days after a rain storm here but the temps have been in the high thirties or low forties so today I am still stranded with a non-starting truck.
BTW, if I pop the hood, remove the air cleaner assembly and carefully watch the TBI injectors while cranking the motor I do see fuel being squirted into the TB so I am fairly well convinced it is an issue with the spark rather than a fuel problem.
On dry days the truck always starts quite easily.
Any suggestions would be most welcome.
« Last Edit: April 12, 2025, 02:29:06 pm by JensenHealey »
Re: 1987 R20 w/454 TBI motor not starting after heavy rain
« Reply #1 on: April 12, 2025, 02:36:43 pm »
Remove the distributor cap, flip it over, and check for condensation inside the cap.  Remove the coil wire from the cap and cautiously hold it about 1/4" away from bare metal as an assistant cranks the engine to check for spark.  Be careful to not get nailed by the spark.
« Reply #2 on: April 12, 2025, 02:46:20 pm »
OK, I will go out and try this now. No assistant here but I can try to look at the cap.
Thanks for the suggestions.
Offline berserk
« Reply #3 on: April 13, 2025, 12:20:12 pm »
If you have to, Harbor Freight has a starter bump switch. You can attach the leads under the hood and with the key on use the bump button to turn the engine.
76 Chevy k10 350/th350/203 part time. Vortec head 350 Dana 60 w/Detroit, 14 bolt Tru Trac, 33" Micky T. Mudders.
