Author Topic: motor mount question  (Read 22869 times)
Offline revevans3
« on: May 12, 2025, 10:45:29 pm »
81 short bed, 5.3LS, 4L80e. I'm having trouble getting my pinion angle correct as my 4L80 is up as high as it will go and the angle is still out by 3-4 degrees. I'm currently using ICT Billet motor mounts and wondered if anyone has a suggestion for lower profile motor mounts?  Thx
Re: motor mount question
« Reply #1 on: May 14, 2025, 10:57:13 am »
What is the angle at the Trans?  What is the angle operating angle of the driveshaft?  What is the angle of the pinion?
How are you measuring the angles and where?
Video on what I am talking about: https://spicerparts.com/calculators/driveline-operating-angle-calculator
Offline revevans3
« Reply #2 on: May 14, 2025, 11:02:37 am »
thx for the reply. I've read and watched the spicer stuff which is what I'm following, at the moment my rear end (10 bolt gmc w/373 gears) is up at 2 degrees while my transmission is down at 6 degrees and the trans is hitting the tunnel. am I doing something wrong here? thx again
Offline revevans3
« Reply #3 on: May 14, 2025, 11:14:14 am »
I'm measuring the angles on the flat part of the yoke.
« Reply #4 on: May 14, 2025, 12:41:22 pm »
Stock height, lowered?  If lowered howin the rear?  Who's trans mount for the 4L80E?
If the trans angles down 6, and the Yoke is 2 degrees up, what is the Driveshaft angle?
