Author Topic: 86 suburban manual trans conversion  (Read 22543 times)
Offline bofourfiffa
« on: January 14, 2002, 10:51:00 pm »
does anyone out there have any info on what kind of manual transmissions would fit in the burban and if there were any burbans that came with stock manual transmissions (there had to be at least some, right?). i have a crazy idea for a T56 six speed swap into my 86 sub....i dunno. thanks
Offline 1979blazer
i had a 73 with a 4spd
« Reply #1 on: January 16, 2002, 12:39:00 am »
i dont know what kind you want or whatever, but i had a 73 subby with a 4 spd manual, it was a 4x4.
i am very sure it was stock, it had a 350, 4spd, 205, 1/2 ton, 3:73 gears and a factory posi in the rear.
the thing i hate about standard in big trucks is, when you flex the body (going over curb) the linkage would pop out, i dunno, my 73 body wasnt the best but not to bad either. also my 74 blazer did this too, so if you can, go with a hydralic set up for clutch control ;o)
thats all i can tell ya
Offline racedvl
88 manual trans
« Reply #2 on: September 01, 2002, 08:38:00 am »
I have seen a 88 V10 suburban 4x4 that was a 4 speed.
Offline GeoPol
Re: 86 suburban manual trans conversion
« Reply #3 on: October 01, 2002, 02:54:00 pm »
I have an '86 K2500 with a 350 engine and a manual transmission. It is a SM465 4-speed with a granny low of 6.59:1 (I think). I've never seen a 'Burb with a 6-speed, but I know that you could swap a NV4500 5-speed into a 'Burb. One resource is Advance Adapters, but I seem to remember reading something about using a Dodge version of the NV4500 rather than a GM. This is the same swap I hope to make in the coming years (2006 if I'm lucky).
Offline scooterskoolkustoms
« Reply #4 on: February 20, 2010, 02:17:31 pm »
V10 WOULD THAT BE A VIPER MOTOR?
82 burb 350-700r4
« Reply #5 on: February 20, 2010, 02:28:05 pm »
In 87 GM made what the C-10 2wheel drive to R-10 and the K-10 became the V-10.
« Reply #6 on: February 21, 2010, 12:55:36 am »
any trans will fit the burb with a little cutting and modding
Offline Mr Diesel
  • Aaron
« Reply #7 on: February 21, 2010, 06:53:08 pm »
This thread is over 7 years old, guys.
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
« Reply #8 on: February 22, 2010, 02:07:38 am »
lol sh i was hoping bofourfiffa, 1979blazer, 1979blazer and GeoPol  would reply ::)
« Reply #9 on: February 22, 2010, 06:29:11 pm »
7yr's.looks like there are more new posts than old
82 burb 350-700r4
« Reply #10 on: February 22, 2010, 08:01:33 pm »
Cut em a little slack.  He more than likely found this site like I did, googling a problem then started poking around and asking questions.  That is how we learn.  For Newbies all posts are unread.
« Reply #11 on: February 22, 2010, 09:15:11 pm »
scooter didn't pull it up..
