Author Topic: Horn honks when hooking up to battery  (Read 65554 times)
Re: Horn honks when hooking up to battery
« Reply #15 on: May 09, 2026, 03:58:27 pm »
Here's another thought.  With the lock plate flipped upside-down, nestle the c-cam into its normal position against the lock plate in the same way the parts would be assembled in the column.  Does any part of the c-cam brass contact ring touch the lock plate?
Offline MY1978
  • Just a girl and her truck since 1978
« Reply #16 on: May 09, 2026, 05:33:00 pm »
Thanks, I will try that.
Offline MY1978
« Reply #17 on: June 21, 2026, 12:54:25 pm »
Hey, wanted to let you know that I FINALLY worked slowly and carefully looking at each part as they went into place.  I placed the locking plate in place (not compressed with retaining clip) and pressed on it several times.  No honk.  I then moved on to securing the plate in place, No Honk.  I put the steering wheel back together piece by piece checking for honk.  Once all together, and battery was connected.  No Honk!!!!!  unless I pressed on horn button.  So, the only thing different is the insulator on the c-cam.  Something on the other c-cam must have been grounding it?  I also changed out the relay, just in case.  So, it seems like THAT is fixed.
Thank you so much for your time, expertise and pictures.  Now, I have another issue that I will be posting in another forum about my brake light.
