Author Topic: Happy Spring Everyone...  (Read 48164 times)
Re: Happy Spring Everyone...
« Reply #15 on: May 15, 2026, 05:40:29 pm »
Thought so. "Raised Detail", you hear that bd? Glad to know they're making them both ways now.
It's amazing how interchangeable these trucks are
Here's the 'correct' side mirror on a '80.
Didn't know they ditched the dumbo mirrors that year...
The term "dumbo mirrors" is misused and confused time and time again. They called the 3 legged "dumbo" mirrors Below Eyeline Mirrors. In 1980 the regular "Truck" Mirrors were introduced and also called Below Eyeline mirrors but have the mount hidden under the cover. In 1981 they were also available in white, not just stainless.  PS those round mirrors I assume you are joking. The attached shows the 79 mirror options.
Offline JohnnyPopper
  • Old Goof
« Reply #16 on: May 16, 2026, 01:58:34 pm »
One of those pics (bottom left) is from San Diego, when you could still DRIVE on the beach! Stinkin doo-gooders...well, having said that, there IS one beach left where you can. Fiesta Island. You should see the looks of the above referenced ilk when they see you driving...Shock, disgust, and in your face! till you say calmly, 'hey, it's legal to drive on the beach here'...
I'm not well versed on 'all things correct', so assume these are factory rounds. There is no other bolt pattern on the door.
In fact, when trying to remove, one of the factory threaded plugs started turning in the door skin. Good thing I had planned to restored the door soft parts and had access to tighten.
1980 C-10 under construction
  • Old Goof
« Reply #17 on: May 16, 2026, 06:47:38 pm »
Well, I just went into the garage where this beast resides, and lo and behold! There are among the patina and greeny paste, 2 holes that have been filled.
They fit the description and location of the two lower pics VZ posted.
VZ, I repent in sackcloth and ashes. You are the man!
Still curious about how these mirror options were offered and delivered to the buying public.
I better be quick, the generation is moving on...
« Reply #18 on: May 17, 2026, 07:54:35 am »
Someone decided to put them on there definitely not something that was ever offered on these trucks. For 80 you either had the sport mirrors or the 9x6.5 BE mirrors. The sport mirrors look good but honestly they suck for any practical use.
« Reply #19 on: May 18, 2026, 11:36:53 am »
During GM Tailgate Tour( yall really gotta do this) this past March, I had an AC mishap and leaves were blown into the AC box and well they started smoldering while I was driving.  We were able to get it out but the box melted.  I patched it with some Flex tape and a piece of metal and continued.
This is from the smoldering leaves and it smelled!
When I got home my plan was to put the original bed back on the truck.  So that started (I will be updating the Project page also)
11 years had past since this bed was on the truck!
Which forced me to finish this:
I am currently fixing the melted AC Box by replacing it, this is the damage:
Firewall was cleaned up (along with a lot of leaves/debris in the lower cowl
All of my trucks except the 1997 Silverado are "patina" or unpainted originals.  That way I am less likely to be disappointed when something happens.
Not sure what I am going to to about the 1989 K5 Blazer project for paint though...
  • Old Goof
« Reply #20 on: May 23, 2026, 03:43:19 pm »
Bizarre! What was the cause of ignition?
« Reply #21 on: May 24, 2026, 01:24:16 pm »
Blocked off cowl drain, to many leaves and the fan sucking them in and blowing into the AC box apparently into the resistor and creating ambers.
I haven't been consistent on cleaning out the cowl....
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #22 on: July 08, 2026, 09:54:10 pm »
That's crazy!  Glad it turned out okay!
What you did to fix that needs to be in the Technical Pages Section.  That affects every square owner on here.
« Reply #23 on: July 09, 2026, 11:53:01 am »
It actually is posted here: Annual Cleaning out the cowl
  • Z62 ON-ROAD
« Reply #24 on: July 11, 2026, 01:17:03 am »
Nice!
Offline philo_beddoe
  • 77 C-10
« Reply #25 on: August 01, 2026, 11:14:53 am »
Well now it’s happy summer, and nearly happy fall…lol
